Installed HID kit DO NOT USE 55w KITS
Re: Installed HID kit DO NOT USE 55w KITS
Postby C8XY » Tue Apr 12, 2016 10:44 am
Veki007 wrote:Hi
I had a same problem but because I was under warranty Ford cleared error for free but someone mention here on forum that they charge around £150 if i remember correctly .And unfortunately unplugging battery does not help i had a aa coming out and they were not able to clear code.So i would advise you to go to Ford and save your self a hassle.
Sent from my SM-G900F using Tapatalk
Thanks Veki, mine is under warranty so I'll put everything back to halogen and take it to a main dealer.
£150 is more than the kit!
C8XY
Postby mavericktc » Tue Apr 12, 2016 1:41 pm
C8XY wrote:
Veki007 wrote:Hi
As I said before, why not pay it yourself?
This is your own fault, why make ford pay it?
You (UK guys) rant about the dealers prices but you have no problem leaving a van for repair that YOU messed up.
No wonder they are expensive...... :roll:
mavericktc
Postby Veki007 » Tue Apr 12, 2016 1:47 pm
mavericktc wrote:
C8XY wrote:
Veki007 wrote:Hi
Well maybe because if is genuine problem they will look into anything just to not respect warranty, you go for what so ever reason to dealer under warranty is not covered or they cannot find any problems in their opinion van with no wheels drive perfectly
Veki007
Postby Mike » Tue Apr 12, 2016 6:55 pm
mavericktc wrote:As I said before, why not pay it yourself?
Some people are like that, they'd be unhappy if their clients did the same to them though.
Mike
Wind up merchant!
Postby C8XY » Wed Apr 13, 2016 8:02 am
mavericktc wrote:
C8XY wrote:
Veki007 wrote:Hi
I guess some people don't like being ripped off, we rely on people like you to financially support ford dealerships. So thanks!
C8XY
Postby Mike » Wed Apr 13, 2016 8:29 am
C8XY wrote:I guess some people don't like being ripped off,
I don't blame them, you wouldn't like being ripped off, why would Ford?
Mike
Wind up merchant!
Postby C8XY » Wed Apr 13, 2016 9:24 am
We can all agree that nobody likes being ripped off, I'm not letting ford rip me off... £150 to clear a code is a rip off. There's no argument here....?
C8XY
Postby mavericktc » Wed Apr 13, 2016 9:45 am
Sure there is.
If you didn't mess the van up by installing aftermarket stuff the code wouldn't show up.
If the code did show up and you didn't mess the van up = warranty.
That's what you are trying to do now by installing the correct bulbs again, trying to fool ford that it's a warranty job.
mavericktc
Postby seikokid » Tue May 03, 2016 10:48 pm
I understand people are enjoying the HID lights , I am very tempted but prefer to keep the auto light function .
out of the filament lamps , which type would you suggest for the best light output?
I am replacing the rear lights with leds. I read somewhere you need a canbus cancelling device . Is this necessary for led lights ?
I will be purchasing from autobulbsdirect
seikokid
Postby Mike » Tue May 03, 2016 10:56 pm
seikokid wrote:I am replacing the rear lights with leds. I read somewhere you need a canbus cancelling device . Is this necessary for led lights ?
If you get the Philips X-treme led bulbs they come with the resistors to stop the bulb alarms.
viewtopic.php?f=27&t=140683&start=15#p1177187
Mike
Wind up merchant!
Postby seikokid » Wed May 04, 2016 7:24 pm
great , thanks . just emailing HID4U now about this
I can remember reading but do the fog light HID kits cause problems too?
seikokid
Postby Mike » Wed May 04, 2016 8:30 pm
seikokid wrote:I can remember reading but do the fog light HID kits cause problems too?
I put the Osram LEDriving lights in mine and they didn't throw up an fault codes.
Mike
Wind up merchant!
Postby seikokid » Wed May 04, 2016 8:54 pm
Gotcha.
I've just ordered brake , tail, indicator and reversing led lights that all have included CAN bus electronics in them - will keep you updated as i slowly changed as much as incan
seikokid
Postby seikokid » Mon May 16, 2016 8:01 pm
Mike, do the fog light you fitted come with the correct IP rated and fitted connection plug to connect into the existing fog lights wiring loom without making aftermarket connections ?
Also has anyone got experience with fitting LED indicators ? does the custom use a flasher relay or is it built into the management software ?
seikokid
Postby Mike » Mon May 16, 2016 8:50 pm
seikokid wrote:Mike, do the fog light you fitted come with the correct IP rated and fitted connection plug to connect into the existing fog lights wiring loom without making aftermarket connections ?
The Osram LEDriving DRL/fog/cornering lights come with the correct oem connectors for the fog light connections, the DRL and cornering functions are done by the fitter.
seikokid wrote:Also has anyone got experience with fitting LED indicators ? does the custom use a flasher relay or is it built into the management software ?
I fitted the Philips xtreme led indicator bulbs, they come with the can bus cancellers. No idea how they're controlled though.
Mike
Wind up merchant!
Return to Transit Custom
