Leaking roof
Leaking roof
Postby acegarp » Sun May 13, 2007 8:53 pm
Hi I have an 05 t280 85 LR, it seems to have a leak to the rear roof at the seam, inside the paint has flaked for most of the length of the seam due to rust. Salesman told me to put a bead of sealant along it!
acegarp
Postby MrMPuk » Sun May 13, 2007 8:57 pm
Take it back under warranty before it runs out!
Postby acegarp » Sun May 13, 2007 9:43 pm
Another trip to the dealer. It's already been back with a collapsed bearing in the steering column. back tomo for wiper blades, don't clear the screen at all, dash left loose and rubber boot floating around on steering column.
acegarp
Postby MrMPuk » Sun May 13, 2007 9:48 pm
Wiper blades wont be covered by warranty. but you want to get the body panels sorted as soon as.
Postby Tdci_boy » Sun May 13, 2007 10:09 pm
I have always found my local dealer to be very good at replacing most things under warranty, I have had bulbs & wiper blades done under warranty, I did buy the van new from them so maybe that helps, I was shocked when they did it though
Tdci_boy
GLX Posse
Postby bertsta2002 » Sun May 13, 2007 10:39 pm
i had the same problem with my 01 tranny, had to run white silicon along the seem at the rear of the roof inside and out ,sorted it out
bertsta2002
Postby Nighthawk » Sun May 13, 2007 11:03 pm
the body seam fault will still be covered by warranty.
the rubber boot above the lower bearing on the steering shaft is a loose fit item anyway. Even if it's pushed all the way down it soon rides back up after the steering has turned a few times or you knock it with your foot.
wipers are considered wear and tear and should only be replaced under warranty inside the first 12 months of the vehicles life if they are suffering a manufacturing defect. This is also the case for bulbs.
Has the dash been out for work......whats loose?
Transit.........Job done
Nighthawk
Postby acegarp » Mon May 14, 2007 3:10 pm
Thanks for t replies :)
Off to the body shop then for the rust, spose it comes under the anti perforation warranty.
The wipers were s**te and would have thought they would have changed them before selling to me, no such luck, they just cost me £30, the missus works in t motor trade in service, she cant believe how slack t commercial side of it is!!
Dashboard, it's the cowl above the speedo that was loose and missing a screw since I bought it. all sorted now, they put what looks like a wood screw in it LOL, not a normal screw, jeez could o done it myself but it's the principle of it!!
Cheers guys, am still lovin me tranny tho :D
acegarp
Postby sc_BK » Mon May 14, 2007 3:28 pm
You paid £30 for some wipers? :shock:
sc_BK
Postby acegarp » Mon May 14, 2007 4:54 pm
sc_BK wrote:You paid £30 for some wipers? :shock:
Er yep, better than fitting non gen parts.
I used to run an old landy so am sick of working on vehicles thought I'd try t other way out! Was a bit pricey though.
acegarp
Re: Leaking roof
Postby gemini » Mon May 14, 2007 6:00 pm
acegarp wrote:Salesman told me to put a bead of sealant along it!
bet he wouldnt like that as an answer if it was his car :wink:
gemini
Postby madmark » Mon May 14, 2007 6:14 pm
wow the wipers were expensive , i have had 2 sets under warranty so far ,they doo my head in the drivers side makes so much noise ,as for the seam its common on white vans normaly ,mine looks ok at the moement but is a difrent colour but i am keeping an eye on it! :?
but as mike says get it back under warranty wile you can! :wink:
Postby acegarp » Mon May 14, 2007 8:46 pm
Got a date to see a warranty guy about the rust/leak, 3 weeks! hopefuly get something sorted.
The salesman even showed me the bead of sealant used on the mark 7 to cure it.
acegarp
Re:
Postby pollag » Sat Feb 07, 2009 5:29 am
bertsta2002 wrote:i had the same problem with my 01 tranny, had to run white silicon along the seem at the rear of the roof inside and out ,sorted it out
WHY can't FORD at least GET a ROOF to NOT leak!
New VAN:SWB 85T260-04 Reg - Forum Post ranking:108th -37.4mpg top-New Fuel Pump
Prev VAN :mk4 93' SWB 80, 2.5d Retired -Nov 08' - SOLD :(
Image <--- Click on the little phone
pollag
Re: Leaking roof
Postby ake » Sat Feb 07, 2009 8:20 am
They can now, you get a lovely line of seam sealer on the outside of the joint at the back, looks lovely :lol:
Users browsing this forum: Majestic-12 [Bot], ossie cossie
