Mk1 front axle change to mk2
Postby Jazwood » Fri Oct 28, 2005 11:02 pm
Hi, has anyone changed a mk1 front axle to a mk2 with disc brakes? I'm told its easy as, just a few bolts and connecting the brakes up - is there any hidden probs? Also did the early mk3 have a rigid front axle that could also go on a mk1?
cheers
Jason
Jazwood
Postby Luke » Fri Oct 28, 2005 11:09 pm
Mk1 to mk2 swap is easy mk3 early LWB's had the same axle aslo an easy swap but the taper on the steering joints are different - forget exactly how but i put mk3 axle on my mk1 pickup !! :D
Postby Jazwood » Wed Nov 02, 2005 12:14 am
cheers, luke
Jason
Jazwood
Postby FredTransit » Wed Nov 02, 2005 12:18 am
Have done this in the past, quite easy, and worthwhile too (better brakes)
FredTransit
Mk2 Trannyist
Postby Rudz » Wed Nov 16, 2005 10:00 pm
Does that not cause problems with the braking cylinders?
disk brakes need more pressure, don't they?
Rudolf
Rudz
Postby madmark » Thu Nov 17, 2005 5:00 am
:? i have noticed that mk1 transits with drum brakes have a smaller servo than one with discs! :? hopefully when i do the front axle swap i wont have to change the servo! :?
Postby FredTransit » Thu Nov 17, 2005 11:32 am
We didn't change the servo, and the brakes were fine. Always passed the test anyway.
FredTransit
Mk2 Trannyist
