Hi guys, I have searched for this infomation but couldnt find anything on here, I am hoping to replace the cam/crank sensor on my 11 plate SWB 2.2 FWD (6 speed) 115 300s
its apparently a £10 part and 20 min job.... if you know where to find the bugger!
the reason for this is, couple days ago i went to get some desiel on the way home and when i went to start up again it wouldnt fire, like the imobliser isnt switching off.
after pushing it out the way and trying again after 30 mins fired right up as normal, has done it a couple times since but only had to try it after a few minuites of running a couple times.
first thing in the morning or straight after work when been left a while no problems.
am i in the right thinking this is the problem?
if anyone has a pic of where it is and what im looking at or if i need to be under the van this would be a great help
Matt
