Tow bar conections???
Re: Tow bar conections???
Postby tony12 » Tue Sep 23, 2014 2:27 pm
Hi ive got a problem with a 2009 mk7 ex rac transit ive found the rear plugs for the towbar and the relay and fuse , when I connected the loom to the rear light and the van loom into the towing loom the side light work ok , but the van indicators or hazards wont work at all , but they work if its connected back to the van loom , what could be the problem
tony12
Postby E-B » Mon Nov 03, 2014 1:03 am
TriumphStag wrote:That is the correct connector. I ended up just cutting the connector off, testing each wire to see what it was and then soldering and heat shrinking it to the corresponding wire in the towbar loom. would have been better to use the connector but I did not have time to source one.
Not particularly helpful for your question, but at least you know it is OK to cut and solder.
Did just that. No snags whatsoever.
115T350 DRW Jumbo van - "New Daddyvan" - big plans for this!
125T350 LWB HT - "Daddyvan" - gone but not forgotten.
www.e-bracing.com
E-B
Postby CornOnTheBranch » Thu Jul 21, 2016 6:25 pm
Hi,
Did we ever source a connector? I also have the connector which is located under the spare wheel on my mk6 T280 available. Before I snip, solder and shrink wrap thought I'd ask the question, tried the local scrappy but first thing they take off is the wheels leaving the spare covering the wanted connector!
Cheers in advance
CornOnTheBranch
Postby Adie moore » Tue Jul 26, 2016 5:48 pm
Did this also, just last week, used wago's not solder as I'm lazy. Had to get the indicator over from the other side but no drama.
Adie moore
