What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby MinorMatt » Thu Jul 21, 2016 9:59 am
I got this just under a fortnight ago...
Postby derv23 » Thu Jul 21, 2016 10:39 pm
Replaced pass' door lock. That's them all done now except the fuel cap. That's on a separate key anyway so I'll just leave as is. Back to welding...
MK5 Tourneo.
derv23
Postby MinorMatt » Fri Jul 22, 2016 8:58 am
Stuck a bosge strip on the bottom of 1 rear door... the other one will be done next week
Postby CamperVanBeethoven » Sun Jul 24, 2016 8:41 pm
Went to a wedding. Slept in it. Then drove home :)
Did see another Mk5 based camper going up and down the A1. There's still some of us left ...
CamperVanBeethoven
Postby Kev1000s » Mon Jul 25, 2016 7:06 am
Bad oil leak, gearbox out , new rear ford crank seal and gasket, new clutch gearbox back in.... :D
Ford FDS 2000
52 plate , Smiley 150lwb ,Td,Ex police :)
1996 Smiley 100 ,Td-Intercooled , lowered 50mm,mk6 wheels,lsd 4.11..
Kev1000s
Postby weseeyou » Thu Jul 28, 2016 7:18 am
Kev1000s wrote:Bad oil leak, gearbox out , new rear ford crank seal and gasket, new clutch gearbox back in.... :D
have the same problem with mine :roll: how long did it take you and how difficult ? don't suppose you took any pics
weseeyou
Postby weseeyou » Thu Jul 28, 2016 7:28 am
Not used my Smiley campervan for a couple of years . Noticed bad milky appearance at bottom edge of windscreen.
This is what I found when i removed the plastic trim . Yuk!..
Don't let this happen to you . You need to remove the plastic trim to get at the lower edge of the windscreen .There is a 1/4" gap beneath the windscreen under the trim which gathers dust which turns into mud when it rains and seeps into the laminate at the edge of the screen.
I cleaned the area, dried it thoroughly and treated the rust. To hide the milky stain I am going to cut and fit a strip of vinyl tint across the lower edge of the windscreen . I expect it will need replacing periodically .
weseeyou
Postby weseeyou » Thu Jul 28, 2016 7:32 am
MinorMatt wrote:Stuck a bosge strip on the bottom of 1 rear door... the other one will be done next week
what the heck is a 'bosge strip' ? :?
I need to treat the rust at the bottom of my rear doors this week.
weseeyou
Postby MinorMatt » Thu Jul 28, 2016 4:39 pm
Meant to read "bodge"
I.e. a piece of alu. angle!
Postby CamperVanBeethoven » Thu Jul 28, 2016 10:20 pm
Swapped the sliding door lock. Had to rebuild it from being a left hand drive van lock (unlocks with any key!) to being a right hand drive sliding door lock (locks with any key). You need the old lock housing, and swap the discs around after disassembling lock. Phew...
CamperVanBeethoven
Postby wazzadj » Fri Jul 29, 2016 5:02 am
Went for a short trip across state 4,700km to get my house furniture ,
got back found steering pump hanging on with one bolt, oil filter leaking very loose , leaking thermostat gasket , adjusted and retuned injector pump too much black smoke
so was a little busy fixing minor issues
:D
1994 MK4 2.5DI Auto High Roof Australian Style 1996 2.5 TDI with rebuilt AUTO Bring on the power !!!!
wazzadj
Postby wazzadj » Fri Jul 29, 2016 5:07 am
woke up decided that the back door lock mechanism that has not locked since had needed fixed
wow what a headache to get out
OUCH some dumb nut drilled 2 screws into the cam mech
OK so now i have to try to fix old mech or source another secondhand one MISSION IMPOSSIBLE
so door shut and cabletied around handle
:D
wazzadj
Postby Kev1000s » Fri Jul 29, 2016 8:46 am
New sump gasket & lift pump o ring fitted hope thats the end of the leaks, and fitted rev counter clocks... :D
Ford FDS 2000
Kev1000s
Postby BROWNYS V6 » Thu Aug 04, 2016 7:25 am
been enjoying smoking the van back and forth to work, did a bit more t cutting yesterday too :D
BROWNYS V6
Postby Kev1000s » Thu Aug 04, 2016 12:00 pm
100ps injectors fitted and leak off mod.... :D
Ford FDS 2000
Kev1000s
Users browsing this forum: samedog11
