What did you do to your connect today?
Re: What did you do to your connect today?
Postby ucmanster » Tue Jul 12, 2016 4:27 pm
changed gas in air conditioning sistem. Now it is cool like in heaven. :)
ucmanster
Postby connect-roadhaul » Wed Jul 20, 2016 7:04 pm
Fitted new wing repeaters as the old ones had yellowed/faded
connect-roadhaul
Postby DIESEL SAM » Sun Jul 31, 2016 5:57 pm
Fitted some silicone intracoola pipes as the originals where blowing out and boy do it pull better !
And I polished it !
DIESEL SAM
Postby mrtn » Sun Jul 31, 2016 10:27 pm
DIESEL SAM wrote:Fitted some silicone intracoola pipes as the originals where blowing out and boy do it pull better !
And I polished it !
Nevermind the Connect, more info on the Big Rig, plz?
1.6 Ecoboost A/T LWB '16
mrtn
Postby DIESEL SAM » Tue Aug 02, 2016 8:41 am
Ho everyone likes my big red Kenworth :wink: it's a 1978 W900 has a Catapillar 14L 425hp motor 13speed trans
DIESEL SAM
Postby DIESEL SAM » Tue Aug 02, 2016 1:40 pm
Did this a few weeks ago
As iam in to radio stuff I fitted a HF Ham radio (bit like a CB but lots better) it had a split power system fitted in so I modified it with a 200Amp relay and some 40Amp cable to a mobility scooter battery via a 50Amp fuse mounted near the main battery I also installed a A/V meter just to keep a eye on things along with a Ext speaker and a remote head SWR/PWR meter
I won the Kenwood meter on eBay for £25 it needed a squirt of contact cleaner on the calibrate VR the it worked a treat
Ext speaker eBay £5 it came off a Royal Navy boat that was being chopped up in Scotland
Relay also off eBay for about £10 and yes the V/Ameter from Hong Kong £3.50 eBay the cable I liberated from a job on a solar farm last year should handle upto 50-60Amp
Ext speaker Image
Relay for split charge and shunt for V/A-meter
V/A meter
Remote head SWR/PWR Meter
I added a ATU and antenna that I got off eBay ICOM AH2-ATU & AH2b-ANT
Antenna mount
Some Spring mounts so you can see how big it is
ATU mounted to the bulkhead
Huge whip
Most people like gardening and doing other strange things I like to sit on my arse listing or even talking on the radio bit like old form of BookFarce
DIESEL SAM
Postby mrtn » Wed Aug 03, 2016 12:33 am
DIESEL SAM wrote:Ho everyone likes my big red Kenworth :wink: it's a 1978 W900 has a Catapillar 14L 425hp motor 13speed trans
Naturally. I had a W900 Matchbox model as a kid, saw it somewhere at my Mum's house just recently, almost destroyed by numerous generations playing with it.
mrtn
Postby AaronP » Wed Aug 03, 2016 7:02 pm
Planned out my camper conversion...
AaronP
Postby ucmanster » Fri Aug 05, 2016 7:32 am
@AaronP, nice!
ucmanster
Postby ucmanster » Mon Aug 29, 2016 3:41 pm
hi guys!
does someone of you have some experience with or without rear silencer exhaust sistem?
mine has original just middle silencer, but I found this on ebay In it is not very expensive.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :3160#shId
I'm just afraid that it would lose some power if I put sistem with two silencer...
ucmanster
Postby surfjunkey » Thu Sep 01, 2016 9:03 pm
Fitted new alloy wheels
Washed the van
Updated tyre size & PCM update Via IDS
Road test & van is smoother with more power & speedo is true.
Happy days.
surfjunkey
Postby bluecraig0776 » Fri Sep 02, 2016 1:30 am
Fitted more lights and CB radio
bluecraig0776
Postby doebag » Thu Oct 06, 2016 3:38 pm
Cleaned it inside and out, took it for an MOT
Passed with a couple of minors that can wait till the winter is here.
Rear brake pipe corrosion
Ball joint cover grease tight but deteriorated
Drivers seatbelt stitching slightly frayed.
Not bad for 105,000 miles
doebag
Postby algieboy » Thu Oct 06, 2016 9:00 pm
ucmanster wrote:hi guys!
I have just replaced mine for its MOT its a 07 lwb and that has just the one middle box and tail pipe Price from the motor factors including new gasket and u bolt and exhaust paste £78 and it looks like quality steel ie nice and thick stuff. Sometimes its best to shop around with a couple of calls to your local suppliers.
algieboy
Postby matt108 » Fri Oct 07, 2016 11:32 pm
Got my first FTC (she's old..) recently... so removed the nasty & heavy roof ladder & the roof appeared all green. Next I cleaned it nicely and shines like new :-) Engine parts in post atm so looking forward to it.
matt108
