Mk6 wont start after fuel filter change
Postby Handyvan » Tue May 22, 2007 1:11 pm
Hi, My mk6 85/280 only ran for a short time after i had changed the fuel filter, should it be a self bleeding system or is there a particular method for this?
Derv is the way to go :)
Mk6 85 / T280 SWB
Handyvan
Postby gemini » Tue May 22, 2007 1:14 pm
did you fill the fuel filter before refitting :?: is it on correctly :?:
gemini
Postby Handyvan » Tue May 22, 2007 1:18 pm
The filter is full and correctly aligned before fitting, It ran for about 30seconds before making a horrible sound similar to a knocking bottom end. I have good oil pressure although the oil level is on the minimum mark
Mk6 85 / T280 SWB
Handyvan
Postby MrMPuk » Tue May 22, 2007 2:38 pm
The horrible knocking was diesel knock. Nothing to worry about, fill the filter with diesel and bleed the injectors.
Postby Handyvan » Tue May 22, 2007 2:59 pm
MrMPuk wrote:The horrible knocking was diesel knock. Nothing to worry about, fill the filter with diesel and bleed the injectors.
thanks for that.... my next job :)
Mk6 85 / T280 SWB
Handyvan
Postby Handyvan » Tue May 22, 2007 6:42 pm
Well that sorted that out, thanks for the replies, however i did have quite a head scratch over replacing the front brake disc's...
...turns out i had to remove the front hubs including bearing from the strut via the bolt holes thu the discs and then the discs come straight off without interfering with front wheel bearings....
would have been nice to figure that out BEFORE spending an hour wondering why my biggest hammer wouldnt move it :roll: :roll:
Mk6 85 / T280 SWB
Handyvan
