Taxistu wrote:Had my letter through. Vehicle just out of warranty. Transit Tourneo mk7 2.2. 3-4 hours they reckon. Does this mean free oil change then??
Yes
andrusl wrote:Model/Variant Assembly Plant Affected Build Periods (inclusive dates)
Transit -- Kocaeli from 1/10/2011 to 4/10/2013
3S549 - Transit Puma Oil Pump
Affected vehicles will be identified on OASIS. This Service Program is limited to only those vehicles that have been identified as high mileage usage / or with specific drive cycle conditions, within the build range shown below.
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
VIN Number: WF0XXXTTFXCT15075
Registration Number: YT13JVM
First Registration Date: 14.03.2013
Registration Country: GB
Outstanding Field Service Actions
No Campaign Message(s) found
walt1984 wrote:Check with ford dealer dosent cost out for piece of mind, maybe see if they will do a print out to show its not effected.
Yours is a 13 plate different pumps might of been fitted at factory.
Digrizrat wrote:walt1984 wrote:Check with ford dealer dosent cost out for piece of mind, maybe see if they will do a print out to show its not effected.
Dealer claims I'm not affected... guess there's not much else to do.
Digrizrat wrote:andrusl wrote:Model/Variant Assembly Plant Affected Build Periods (inclusive dates)
ETIS is telling me I'm not affected, checked right now, but I think I'm a euro5 engine in the date rangeTransit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
Is http://www.etis.ford.com up to date? Should I talk to a dealer to check for this? I've heard a lot of bad stuff about the oil pump from you guys on the forum.
ake wrote:Have you owned this vehicle from new?
Has it been repaired before you owned it?
