by seikokid » Fri May 20, 2016 10:27 pm
HIDs connected up with the loom , 1 side worked fine but the other flickered, worked ok but not as bright then stopped working . After a reset it worked again but flickering to start and not full bright
Too much hassle , going for brighter standard H bulbs hassle free
Still waiting for Phillips indicator lamps to arrive . I'm curious to see if just using the higher wattage resistor cures my problem. HID4U supply 10 & 5 w so might need something higher ?!?
Reverse , Rear fog , number plate and top brake light LEDs working perfectly
Tail works fine , brake brings up fault on first use then not until van is restarted
Indicators flashing fast rate but work normal on hazard
