Can run-flat tyres be an option?
Postby AngelaF » Mon Nov 28, 2016 1:52 pm
Hi all there!
I've got the question about the specific kind of tyres. I'm going to visit all Europe on wheels and do not want to break my journey because of the unexpected tyre puncture.
My husband was advised to opt for run-flat ones in the https://www.giga-tyres.co.uk/, cause they are more reliable during a long ride. He wants to equip my car with the best means for safety, but I guess it is overestimated.
I'm a little bit confused because of this. Can't the classic tyres be an option?
Is this protection really such a good one?
if somebody uses such kind of tyres and can share his thoughts about this, I would be very grateful.
Do not want to waste my plans due to such a tiny detail.
Thanks for all replies in advance.
AngelaF
Re: Can run-flat tyres be an option?
Postby g-man » Mon Nov 28, 2016 2:21 pm
u can only go a about 30mph for no more than 50mls max even on runflats
g-man
Postby Altransit » Mon Nov 28, 2016 2:58 pm
g-man wrote:u can only go a about 30mph for no more than 50mls max even on runflats
This is a problem with them, and unless you have a spare wheel, you need to get the tyre repaired or replaced pronto, to continue a long journey.
They are no less prone to puncturing than any normal tyre, and their life is shorter as far as wear is concerned, so their higher price offers very little advantage.
One (probably the only) advantage is that in the case of a full puncture, they can often be driven to a safer place to change the wheel, but a split or rip in the tyre casing, or damage to the wheel bead, will cause even a run flat to deflate rendering it useless :(
Postby AngelaF » Tue Nov 29, 2016 10:03 am
Oh, I see. Thank you for your answer. In such a way I guess that run-flats can be only a forced solution in cases of emergency. :(
They can't provide a safe long-lasting journey if any trouble with your tyres occurs.
But the possibility to get to the nearest station to change the punctured tyre is obviously a profit.
AngelaF
Postby Mike » Tue Nov 29, 2016 10:11 am
You probably need to think about the availability of run flats in the areas that you'll be travelling in. Also, don't runflats need specific wheels?
Mike
Wind up merchant!
Postby Altransit » Tue Nov 29, 2016 11:12 am
Mike wrote:You probably need to think about the availability of run flats in the areas that you'll be travelling in. Also, don't runflats need specific wheels?
That's another disadvantage I forgot to mention, not every tyre shop can deal with these, and the chances of them having another tyre in stock is minimal :roll:
I would rather start the journey with 4 new, good quality tyres, (my choice would be Michelin Agilis!) and carry 2 spares to make you more or less independant :D
Postby g-man » Tue Nov 29, 2016 6:01 pm
good thinking batman :wink:
g-man
Postby Jim Archer » Fri Dec 23, 2016 8:06 am
Run-flats on a van just doesn't bear thinking about :shock:
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby darkbluevanman » Fri Dec 23, 2016 8:40 pm
A lot of tyre places do the puncture preventative stuff now, 20 quid a shot round here (though diy stuff on t'ebay) I'm not talking the tyre foam stuff you use after a punc either.., really does work too...
darkbluevanman
Postby bigjohnthomas » Fri Dec 23, 2016 10:48 pm
That puncture stuff in a squirty tin is Bob on
Sooty had 3 tyres that kept going down every 2 days
1 tin between the 3 of them and a bit in the wheelbarrow tyre spun them a bit
In the summer and they haven't gone "down on me" since
Wink
bigjohnthomas
Postby mavericktc » Sat Dec 24, 2016 1:25 am
Don't overdo it, don't worry so much.
Just keep a regular spare wheel and maybe two bottles of "filling foam"
Been on bikes, vans, cars all over Europe. Sometimes without any spare at all.
Don't worry, be happy.
Have a good insurance that cover aid abroad.
mavericktc
Return to Transit Talk
