Loots Red custom
Re: Loots Red custom
Postby loot » Tue Dec 13, 2016 11:40 pm
:lol: i forgot to connect the ground to my mk7 fogs :oops:
07 350 170ps
Ids map here
loot
Postby Altransit » Tue Dec 13, 2016 11:44 pm
loot wrote::lol: i forgot to connect the ground to my mk7 fogs :oops:
:? Isn't it just one two pin plug on the Mk7 :?: :P
Postby loot » Wed Dec 14, 2016 12:05 am
I added fogs to mine like everything else which included the wiring :lol:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Wed Dec 14, 2016 12:51 am
I once spent hours trying to find a nip on a fat birds knocker
turned out I was fiddiling with the top of her arm :oops: it still did it for me though :P
hummmm baby ;)
I can still smell it now
billingsgate
bigjohnthomas
Postby dirtydog » Thu Dec 15, 2016 6:42 pm
Altransit wrote:I did something similar, once, fannying around with the non-working fog lights on the Sierra, checking fuses, wiring, relays, and switches.
Eventually I took out the lamp units, only to find that both bulbs had blown :oops: :roll:
Similar thing with me, both brakelights on the shogun weren't working, checked fuses, replaced the switch, turned out both bulbs had blown. I had dismissed it being the bulbs as what are the odds of both bulbs blowing at the same time :roll: :oops:
dirtydog
Postby loot » Sat Dec 17, 2016 4:41 pm
Turned my drl back on save the feds earning more for the xmas ball :lol:
The hunt for why the engine sounds like a tank at 3rd throttle continues :?
Unplugged egr, no difference.
Unplugged the sensor on the inlet (maf?) No difference except esp mil and hla failure.
Been will around the block with ids and can't find any problem.
Has to be mechanical, next checks are too remove belts, unplug injectors one by one then big hammer :lol:
No pcm updates available either. :-(
07 350 170ps
Ids map here
loot
Postby nick217 » Sun Dec 18, 2016 11:47 pm
Punto443 wrote:I can do corrolla's and veedubs in mine :lol:
My brakes are excellent too,it must be my mince pies? :lol:
:roll:
nick217
Postby loot » Mon Dec 19, 2016 5:54 pm
Had another look at it today, unclipped injectors, they don't start up again when you plug them in again lol so get to 3 and it conks out.
I need to spend a bit of time taking the drove belts off to do that check, but you know when you can't be arsed doing something :?
07 350 170ps
Ids map here
loot
Postby boltondigger » Mon Dec 19, 2016 5:57 pm
Wooden handled screwdriver and ear ? Old fashioned but might be worth a try.
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby loot » Mon Dec 19, 2016 6:36 pm
Thought about that but i think it is pulley related, removing the 2 belts will tell all i think, then the screwdriver method will be used after, should make it easier too :-)
07 350 170ps
Ids map here
loot
Postby ake » Mon Dec 19, 2016 8:40 pm
loot wrote:Thought about that but i think it is pulley related, removing the 2 belts will tell all i think, then the screwdriver method will be used after, should make it easier too :-)
How many miles has it done since you put it on the road?
Have you reset all the fuelling parameters?
Postby loot » Mon Dec 19, 2016 9:13 pm
About 400+ i reset them all yes :-)
Done some motorway, town, cold and angry red lining it like i stole it. :lol:
Should have bought a transporter :shock:
Love Ford really. :wink:
Bloody junk :twisted:
07 350 170ps
Ids map here
loot
Postby ned » Mon Dec 19, 2016 9:19 pm
Surfing down Rhyl eh :wink: :lol: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby paul2012 » Tue Dec 20, 2016 7:51 pm
loot wrote:Had another look at it today, unclipped injectors, they don't start up again when you plug them in again lol so get to 3 and it conks out.
I'm fairly certain there's a TSB for injectors on Custom & mk8's
Something about injectors being assembled incorrectly :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby karl » Tue Dec 20, 2016 8:46 pm
:shock:
karl
Tranny Lover!!!
