now I'm without headlight.
I hope that HIDS4U will replace in warranty, I'm sending an email
keeff wrote:Test for power before the HID kit if it is dead then you could be looking at getting the ecu reset at the dealers . I had this with mine as the ecu had some sort of built in electronic cut out gone are the days of just a fuse.
Sent from senderPhone using Tapatalk
arf33 wrote:keeff wrote:Test for power before the HID kit if it is dead then you could be looking at getting the ecu reset at the dealers . I had this with mine as the ecu had some sort of built in electronic cut out gone are the days of just a fuse.
In fact.
Yesterday I tested the HID on the bench with 12v supply power and it work pproperly. On the other hand I put a normal HD bulb in the van and doesn't work. So it means that, as you said, there is a power cut from electronics.
By the way I already contacted HIDS4U and they told me that now they are replacing the ballast with version 2 because many custom owners are getting similar problem. They can replace under warranty, so I'm in doubt if reset Ecu and keep these ballast or send back for replacement
radioman6923 wrote:I have a 2016 Ford Transit Connect XLT here in the USA. Do I need Canbus ballasts for my HID kits?
Mike wrote:The 55w kits draw too much current at start up. There's a thread in the Custom section about hid's, all the info you'll ever need.
Mike wrote:radioman6923 wrote:I have a 2016 Ford Transit Connect XLT here in the USA. Do I need Canbus ballasts for my HID kits?
FFS, I've already told you once,Mike wrote:The 55w kits draw too much current at start up. There's a thread in the Custom section about hid's, all the info you'll ever need.
Not what you said on your other thread?radioman6923 wrote:They have 35w canbus ballasts
Anyway, yes you need can bus ballasts and a 35w kit..........it MIGHT work, no guarantees.radioman6923 wrote: I've tried the harness with anti flicker capacitors and 55w slim ballasts...........Today I tried just a direct hook up..no harness and used 55w canbus ballasts but still they did not ignite.
radioman6923 wrote:Not sure why they won't work for my van?
Mike wrote:radioman6923 wrote:Not sure why they won't work for my van?
HIDS4U kit?
Users browsing this forum: dumper
