EX RAC VAN OWNERS
Re: EX RAC VAN OWNERS
Postby Darren.w » Wed Jan 11, 2017 10:57 am
wronghole wrote:Van officially down plated , now she is class 4 and not class 7 for Mot. Happy days :D :D :D
How do you go about that mate and what needs done ?
Darren.w
Postby wronghole » Wed Jan 11, 2017 1:16 pm
Simple really fella :D . I used a company called VINTAGS UK tel: 01302 843175 . They supplied my new Vin plate ,about £50. Giving them a call will help. You will need V5c log book , copy of driving licence and your new van weights .( I copied my mates plate weights which were 3000)
3500 )
1600 )
1760 )
When I received my new sticker I filled in the changes on my V5 and along with this, a copy of my new vin and a short note explaining that my van is unlikely to be used as a 330 and would like it to be down plated, Send to DVLA, 4 weeks later received my new V5 showing 300 and no longer 330.
Job done :D . No mods where required other than getting a sticker and sticking over original :D
wronghole
Postby wronghole » Wed Jan 11, 2017 1:20 pm
Van passed its MOT as a class 4 on Monday :lol:
wronghole
wronghole
Postby Darren.w » Wed Jan 11, 2017 7:16 pm
Thanks mate. Does the actual vin number on the dash that can be seen through the windscreen need changed ?
Darren.w
Postby wronghole » Wed Jan 11, 2017 7:59 pm
Sorry mate you misunderstood a bit . you only need to change the weights on your vin plate sticker located inside door the vin number stays the same as this is your van ID :D
wronghole
Postby Darren.w » Thu Jan 12, 2017 10:48 am
wronghole wrote:Sorry mate you misunderstood a bit . you only need to change the weights on your vin plate sticker located inside door the vin number stays the same as this is your van ID :D
Brilliant. Thanks mate. I will look into that
Darren.w
Postby Darren.w » Fri Jan 13, 2017 6:40 pm
wronghole wrote:Simple really fella :D . I used a company called VINTAGS UK tel: 01302 843175 . They supplied my new Vin plate ,about £50. Giving them a call will help. You will need V5c log book , copy of driving licence and your new van weights .( I copied my mates plate weights which were 3000)
3500 )
1600 )
1760 )
Hi. Did you have to send proof that it had been down weighted with a picture of the weight certificate and a picture of the back of the van and the reg. I was told that on the phone to DVSA. Maybe I shouldn't have bothered phoning them to ask. Also did you just put 3000 in the new revenue weight bit in the changes. Thanks
Darren.w
Postby wronghole » Fri Jan 13, 2017 7:57 pm
As previously posted mated .Just get your new weight sticker ,send a copy along with your amended log book and a letter explaining that your van is unlikely to be used as a 330. Job done :D
wronghole
Postby Darren.w » Fri Jan 13, 2017 9:37 pm
wronghole wrote:As previously posted mated .Just get your new weight sticker ,send a copy along with your amended log book and a letter explaining that your van is unlikely to be used as a 330. Job done :D
Thanks will give that a try then.
Will keep you updated. Thanks.
Darren.w
Postby Tango330 » Tue Jan 17, 2017 2:58 pm
markspark71 wrote:And she's almost finished just the wheels to change now
Side bars fitted
And the lights connected :)
Brilliant job Mate :!: Is that just polishing :?:
Mine wants a few dents filling and I was going to get it sprayed, but if you did that with polish I might have a go. :)
Had mine about 3 years but only just found this thread :roll:
Martyn did my bcm stuff, and I got my diff done by the Halifax guys, but it's been wining so I swapped the whole axle out last month. I have fitted side windows and got a rear door with a window and wiper (have to visit Martyn to get that operational), plus I've fitted second row of seats out of a Tourneo.
It's still a work in progress after all this time :lol:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby loot » Sat Jan 21, 2017 6:35 am
All looking great there, shiny :-) like the wheels are they bk?
So tango, wh and martynx have orange vans, that i know of, did all of you swap the axles? :-)
07 350 170ps
Ids map here
loot
Postby wronghole » Sat Jan 21, 2017 7:12 am
loot wrote:All looking great there, shiny :-) like the wheels are they bk?
YES :D
wronghole
Postby wronghole » Sat Jan 21, 2017 7:14 am
Don't know about the wheels though.
wronghole
Postby Tango330 » Sat Jan 21, 2017 10:39 am
I got the boys in Halifax to swap the diff first Mate, but after three years it was getting noisy again :( so I got a newer secondhand one and swapped the lot :roll:
Swapping the whole thing cost me a little bit less when you factor in the oil seals and bits plus tools against the trip up to Halifax :?
Yes I swapped my wheels too, but I stuck with 16s as I couldn't get the load rated tyres for 18s. Martyn down rated his so he gets over it that way, but I wanted to keep the capacity for the extra load and towing :)
T330 RWD now sold
Tango330
Return to Transit Talk
