2.2 TDCi Injector Problems
Postby Peregrine » Mon Jan 23, 2017 7:24 pm
Evening all,
My van (56 plate 2.2 TDCi) is making a bit of a racket from the top end. Also, there is a good amount of oil all over the top end of the engine, so my layman's diagnosis is that one or more of the injector seals has gone.
I've had a good search around the forum, and as I understand it I need the following:
4 x copper washers (Ford part no. F1745686)
4 x rubber seals (injector to cam cover, Ford part no. ???)
2 x clamp bolts (Ford part no. ???)
and possibly 2 x uprated clamps (Ford part no. ???)
I also believe it would be wise to recut the seats using a generic 17mm cutter available on ebay, with a blob of grease to catch the swarf.
Torque setting, according to Haynes is 7Nm + 180 degrees.
Could you please help me by (a) telling me if I've missed anything and (b) filling in the gaps (??? above) with the part numbers I need to ask my friendly Ford garage for?
Thanks!
Perry
2006 Mk 7 85 T260 (now transformed by Vantuner!), new turbo and recon engine
2001 Jaguar S Type 4.0 V8
1936 Morris 8 (engine rebuild in progress)
2015 Royal Enfield 500 Classic
Peregrine
Re: 2.2 TDCi Injector Problems
Postby ake » Mon Jan 23, 2017 8:52 pm
You probably don't need the rubber seals, they usually seal fine once the injectors stop allowing blow by
Postby Punto443 » Mon Jan 23, 2017 9:06 pm
Bolts part no. 1673999 £2.80 each
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Peregrine » Wed Jan 25, 2017 9:51 am
Thanks for the info!
Perry
Peregrine
