Ex RAC Camper Conversion
Re: Ex RAC Camper Conversion
Postby euanryan » Fri Jan 20, 2017 12:48 pm
Stupid question - How do you fix the ply to the walls?...
Transit Newbie, excuse the ignorance... :lol:
euanryan
Postby dumper » Fri Jan 20, 2017 1:51 pm
Self taping screws
Postby teamdave » Fri Jan 20, 2017 10:48 pm
euanryan wrote:Stupid question - How do you fix the ply to the walls?...
Self tapping screw indeed.
Got them from screwfix for couple of quid a box of 100
teamdave
Postby teamdave » Fri Jan 20, 2017 11:25 pm
Finished boarding out apart from the rear door, Ive got special plans for that :wink:
with the gaps (under the floor at rear and by the side door where i couldn't bend the ply into van contour) Ive taped it with duck tape and injected it with expanding foam to fill and give me a good edge / shape to carpet at a later date
teamdave
Postby teamdave » Sat Jan 21, 2017 12:04 am
I insulated the wheel arches, layer of foil bubble wrap, carpet insulation, then another layer of bubble wrap
some storage / battery storage areas going in
teamdave
Postby mr_so » Sun Jan 22, 2017 1:36 am
How is the floor fixed down, have you screwed right through the ply/vapour barrier/celotex/etc, glued all the layers to each other, or is it floating?
mr_so
Postby teamdave » Sun Jan 22, 2017 9:31 pm
mr_so wrote:How is the floor fixed down, have you screwed right through the ply/vapour barrier/celotex/etc, glued all the layers to each other, or is it floating?
Yeah I glued all the layers together with contact adhesive.
The boxing Ive put in for storage etc is fixed to the floor and the sides tying it all together also
teamdave
Postby teamdave » Thu Jan 26, 2017 11:50 pm
Next up Ive built a Seat / bed
Wanted the seat to work as rear or forward facing, have a table option and them convert to a bed.
This is the main seat part and a pic of the side panels that have various slots
teamdave
Postby teamdave » Thu Jan 26, 2017 11:53 pm
finished main seat part
Storage underneath
teamdave
Postby teamdave » Fri Jan 27, 2017 12:05 am
The sides of the seat is designed to have a back rest slotted in to in 3 different positions give the front / rear facing and bed options
teamdave
Postby teamdave » Fri Jan 27, 2017 12:11 am
Just like that!!
Rear facing
Front facing
Bed facing
teamdave
Postby GuyT » Fri Jan 27, 2017 11:43 am
That's awesome. I'm going to do something similar but I really like what you've done.
GuyT
Postby teamdave » Fri Jan 27, 2017 8:27 pm
Cheers, Im well happy with it so far, just wish the bloody weather was better and could crack on with it faster
teamdave
Postby teamdave » Sat Jan 28, 2017 9:25 pm
Now for the table / last part of the bed.
fold away support leg
Slot to allow it to be supported via a rail
support rail for when its a bed
In the bed position
teamdave
Postby shaun7245 » Wed Mar 21, 2018 6:29 pm
Just wondering how you went about trimming the RAC wiring that was connected to the battery about to do this myself at some point! is it as straight forward as just cutting them and taping the loose ends?
shaun7245
