Nighthawk wrote:it's easy to get the wiring from the alternator on the wrong threaded terminal. and in a case like that when nothing is going right, it's often a simple mistake thats overlooked.
could well have been fitted to the solenoid terminal when the engine went in, then autopilot refitted it in the same place when you changed the loom.
I've seen it happen
