mattyyoung wrote:Hi all,
Can anyone recommend somewhere I can buy a cloned ids from?
Regards
Matt
loot wrote:Feet ids turned on and running, connect vcm usb, did you get a prompt to update the vcm? Do it. In ids you should see green arrows top right and red vcm bottom right.
loot wrote:Plug it into the van obd and ignition to position 2 with lights on dash, ids should id, go to toolbox, start new session, all other and ids should then read the van pcm and tell you it is a tdci etc.
Airthies wrote:Bollocky scrote itch! IDS doesn't want to find the asbuilt file.![]()
Bloody pooters
Bloody vans
Bloody CC......
loot wrote:Airthies wrote:Bollocky scrote itch! IDS doesn't want to find the asbuilt file.![]()
Bloody pooters
Bloody vans
Bloody CC......
Do it manually mate
loot wrote:Just save the asbuilt to the desktop, turn off internet and then in config restore asbuilt and then locate the file you put on the desktop abcxyz.ab and it'll restore factory settings, will also reset config preferences tho.
Airthies wrote:loot wrote:Just save the asbuilt to the desktop, turn off internet and then in config restore asbuilt and then locate the file you put on the desktop abcxyz.ab and it'll restore factory settings, will also reset config preferences tho.
Yea thought I remembered locating file before but can't get to that point again I'll go try again after some food and a ginger beer.
loot wrote:Airthies wrote:loot wrote:Just save the asbuilt to the desktop, turn off internet and then in config restore asbuilt and then locate the file you put on the desktop abcxyz.ab and it'll restore factory settings, will also reset config preferences tho.
Sounds good, although can you refer to it as non specific coloured beer pls.
