P1103
P1103
Postby pantherbob » Wed Jan 12, 2011 6:47 pm
Hi to all
P1103??? what does this code mean and what do i need to change, any help appreciated
thanks
Rob
pantherbob
Re: P1103
Postby angeleye » Wed Jan 12, 2011 8:24 pm
p1130 lack of ho2511 switch adaptive fuel limit :?: ....is this a lpg if so have a look at jumbo55 thread further down this page may help :!:
angeleye
Re: P1103
Postby pantherbob » Wed Jan 12, 2011 8:32 pm
hi
this is on a mk7 2.2 tdci
pantherbob
Re: P1103
Postby APH » Thu Jan 13, 2011 12:21 am
You sure about that code :?: , as its the heated o2 sensor (Lambda sensor), which is only on petrol or petrol/lpg models :?
(\__/)
(")_(")
this is bunny
APH
Re: P1103
Postby glenandemm » Thu Jan 13, 2011 12:28 am
P1103 is maf sensor, could be sensor gummed up from egr, have you had an egr lately?
May want an egr,maf and inlet clean up clear the fault and retest!
glenandemm
Re: P1103
Postby ake » Thu Jan 13, 2011 7:37 am
What van is this on? MK7 throw up MAF sensor when egr is failing
Re: P1103
Postby pantherbob » Fri Jan 14, 2011 1:12 am
this is on a mk7 2.2 tdci just had a new egr and have cleaned maf sensor and inlet and still throws up code p1103 , what an absolute bag of crap these vans are!!!
what is going on?????
pantherbob
Re: P1103
Postby winterheating » Fri Jan 14, 2011 1:17 am
pantherbob wrote:this is on a mk7 2.2 tdci just had a new egr and have cleaned maf sensor and inlet and still throws up code p1103 , what an absolute bag of crap these vans are!!!
all emmission control related bollocks, should be allowed to ease off, as manufactures clearly cant keep up with strict limits.
winterheating
Re: P1103
Postby Coxy_in_NZ » Fri Jan 14, 2011 9:57 am
I came across a 48 page document titled
Ford Motor Company Group Diagnostic Trouble Codes
from AUTODIAGNOS and it lists P1103 as
MAF Sensor In Range But Higher than Expected
Hope this helps
Coxy_in_NZ
Re: P1103
Postby bigjohnthomas » Thu Apr 27, 2017 10:35 am
ake wrote:What van is this on? MK7 throw up MAF sensor when egr is failing
Bugger
Bloody ford
bigjohnthomas
Re: P1103
Postby bigjohnthomas » Thu Apr 27, 2017 7:37 pm
ake strikes again :P
P1103 on Tuesday cleared it and today's code is ..p0404 egr actuator stuck closed
A bag of turnips is in the post 8)
bigjohnthomas
Re: P1103
Postby ake » Fri Apr 28, 2017 7:13 am
bigjohnthomas wrote:ake strikes again :P
We'll make sure they are clean this time, not like the last bag!
