Leisure battery
Leisure battery
Postby gatecrasha » Sat May 13, 2017 3:25 pm
Need advice / diagram preferably
For wiring 2 identical leisure batteries.
Have a split charge relay.
Just need to know how is best to wire battery to battery to give 12v but have batteries equally balanced
gatecrasha
Re: Leisure battery
Postby dumper » Sat May 13, 2017 4:00 pm
Both negatives on battery's to earth and both positive together. then for the split charger positive to positive battery terminals and negative to negative battery terminals
Re: Leisure battery
Postby gatecrasha » Sat May 13, 2017 4:19 pm
Found it.
Positives:-
Battery 1 positive goes to battery 2 positive with system positive feed from battery 2
Negatives:-
Battery 2 negative goes to battery 1 negative
Vehicle ground goes from battery 1.
Both batteries are used equally an balanced
gatecrasha
Re: Leisure battery
Postby dumper » Sat May 13, 2017 8:49 pm
You got it
