Idiots guide to IDS
Re: Idiots guide to IDS
Postby karl » Mon May 08, 2017 6:15 pm
My ids ids is still working a treat :mrgreen:
Had a few problems the other week but unistalled and reistalled it and it works again :D
karl
Tranny Lover!!!
Postby bigjohnthomas » Mon May 08, 2017 7:01 pm
bloody craptop wont boot up :x ive chucked the b*stard in the bin that will teach it to f*** with allcock :x
need a new one now :( loads of lights have come on on the arsewash 3000 bloody fords light on on one limp mode on the other
and ford still refuse to admit theres a problem :x
probably
but at least i can rely on sooty :roll:
bloody Italian bag of shite :lol:
bigjohnthomas
Postby Airthies » Mon May 08, 2017 7:15 pm
bigjohnthomas wrote:bloody craptop wont boot up :x ive chucked the b*stard in the bin that will teach it to f*** with allcock :x
probably
Flat battery will stop it booting up did you charge it up?.....
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bigjohnthomas » Mon May 08, 2017 7:18 pm
Its not had a battery for a long time I pulled that to bits to use in my torch
I just plug and go
You know
bigjohnthomas
Postby bigjohnthomas » Mon May 15, 2017 9:59 pm
now th3en ,nowthen guys an gals ...
newlaptop here well wheni say new it was a anotheregay spesh and i dont think the spacebar isworkingverywell :x
so since i f*** up installing itlast timeee what was itagain v86 then somethingelse runxprog and sh*t and all that ?
bigjohnthomas
Postby loot » Mon May 15, 2017 10:02 pm
Yes that's correct :D
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Mon May 15, 2017 10:05 pm
its inthe post
check your bins :lol:
bigjohnthomas
Postby loot » Mon May 15, 2017 11:06 pm
:lol: I'm a bit out of touch with ids for customs, I'd probably break it and your shortcuts to fetish porn would no longer work :cry:
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Mon May 15, 2017 11:28 pm
Its not for billy well not yet anyway the arsewaher is having an egr problem as well now. so its just good old v86 atm
I f*** it up last time so just though I had better ask first :oops:
bigjohnthomas
Postby loot » Tue May 16, 2017 9:59 am
V86, shut down
V86 licence (as admin and xp3) shut down.
Xprog, (admin and xp3 if possible)
Make sure all files are saved to desktop and extracted where necessary.
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Tue May 16, 2017 11:06 am
yeah i am going to try to put it on the big comp before the craptop this time :oops: thing i am not understanding is
well things,admin ? whos that? am i admin? and more worryingly v86 license where will that be
bigjohnthomas
Postby Airthies » Tue May 16, 2017 11:37 am
Right click on what you want i.e. "extended programming"
And the following menus appear
First chose property's and second tab compatibility. Set as xp sp3 click run in compatibility mode
Then apply and ok
Right click again and "run as admin"
Easy peasy lemon squeazy ImageImageImage
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bigjohnthomas » Tue May 16, 2017 11:45 am
8) so the extended programming is the license?
Its not going well on the big computer :lol:
I'll try and do the craptop tonight
bigjohnthomas
Postby Airthies » Tue May 16, 2017 11:51 am
No.
"IDS_Patch_86.exe" is what you run to "have" the licence
"Extended Programming" File gives you the "module programming" options in IDS.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby bigjohnthomas » Tue May 16, 2017 11:55 am
Righty ho :D
bigjohnthomas
