Idiots guide to IDS
Re: Idiots guide to IDS
Postby bigjohnthomas » Mon May 29, 2017 10:20 pm
now then now then hows about that then?
following the sucsess of my v86 install :P
what about v96 ? could do to have a lookat thecustom thatkeepsstarting up inlimp
and get a keyboard with a spacebar :x
but i am going to need some stuff, yes?
deep freeze with a licence key? 4 leezzers and,,,,,, :roll:
the lesbos i haveon standby but the freeze i have not
and i would be able to switch from one to the other so i can mess with the mk7 still,yes?
all is good then
init?
so
howdid you do it loot? :lol:
bigjohnthomas
Postby loot » Mon May 29, 2017 10:56 pm
V96 works on custom and mk7:-)
I paid someone to change my vcm2 serial number to a newer 1 and he also made a exe file that changed time and date and started vmware up and he also stopped clock time update via windows time.
Bit complicated that way tho :?
I also think he used a genuine ids subscription demo as it has 4 days remaining :shock:
No real use on the custom tho because to do keys or initialization it wants to go online and log in to Ford with my locksmith username and password, certainly sir I'll just go and get it :roll: :?
Anyway, i don't know 100% what version your vcm2 serial is valid till, maybe v91, in any case what happens is you have v86 and it identifies the van mk7 say 2.2 tdci yes?
That's fine then it'll read codes etc happy days, them when you update to say v91 it'll do the same mk7, bit then you plug billy in it'll not see the pcm:-( but then v95/6 will see billy and do codes etc, however, v86 has permanent licence, install v91 it now has 3 day licence, install v96 and you'll still have 3 days or maybe what's left I'm not sure.
That's the fun bit you need to lock it up somehow, I've never used freeze successfully, i have this exe which is a shortcut to vmware12 and when i click it, it changes the laptop time and date to 2011 January or something and it runs vmware and then i run ids from within vmware which is w8.
Once i close it down it reverts the laptop time and date back to what it should be, clever really :-)
Pointless tho because I'm not to sure how i can emulate this into another setup :-(
Also Karl bought a vcm ids3 fly clone which I'm waiting for him to see if it'll do keys and modules with bypassing the Ford user and password (it goes online differently see)
HTH did you get all that?
Have you done it yet?
:D
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Mon May 29, 2017 11:25 pm
bloody ell
let me pause for reflection for a moment
:lol:
bigjohnthomas
Postby karl » Tue May 30, 2017 9:49 pm
loot wrote:V96 works on custom and mk7:-)
:D
i have a unique password and dealer identification 8) it works on a 66 plate custom need to check it on a mrk 8
but its all the same as the euro 5/6 systems reset etc for fuel system also injector coding mrk 8 is a must for me :D
the euro 6 has adbule thats the only difference from euro 5/6
karl
Tranny Lover!!!
Postby loot » Tue May 30, 2017 10:36 pm
There's puma 2.2 euro 6 and 2.0 dw psa euro 6, no idea of they program the same tho?
07 350 170ps
Ids map here
loot
Postby vanduara37 » Wed Jun 14, 2017 8:01 pm
Have managed to install v100.01 and updated to 100.02 then 100.03 next step was to install Dfds which is a deep freeze programme.
Ids works fine but I have a 2014 custom and to be honest ids has very limited use on the van, can read and clear dtc,s.speed limiter, injectors etc but just freezes when attempting most other options
vanduara37
Postby loot » Wed Jun 14, 2017 11:11 pm
Try v96
07 350 170ps
Ids map here
loot
Postby vanduara37 » Thu Jun 15, 2017 9:23 am
Where can I get v96 ?
vanduara37
Postby adam75pl » Fri Jun 16, 2017 8:18 pm
Is it possible I can't perform pump learn if SCV and PRV needs changing?
Mk7 2.2
This post only expresses opinion of the author of today. It can not be used against him tomorrow, or any other day following that date. In addition, the author reserves the right to change his views, without prior notification.
T280 SWB 2.2 115PS
adam75pl
Postby adam75pl » Fri Jun 16, 2017 9:09 pm
Temporary learning goes OK but permanent fails...
T280 SWB 2.2 115PS
adam75pl
Postby Hovervan » Wed Jun 28, 2017 8:00 pm
I need URGENT help....
Swapped my BCM, now IDS is not able to upload my Asbuild data:
Anybody has an idea what causes this error? I want to go to holidays on saturday and actually no lamps or headlights are working :cry:
Hovervan
Postby loot » Wed Jun 28, 2017 10:46 pm
Did you initialize the new bcm? Program keys?
I presume you went from a medium level bcm to a high spec bcm?
Can you give us a step by step of what you did and why? :-)
07 350 170ps
Ids map here
loot
Postby Hovervan » Thu Jun 29, 2017 9:39 am
loot wrote:Did you initialize the new bcm? Program keys? I presume you went from a medium level bcm to a high spec bcm?
Yes, yes, yes and yes :)
Changed -BB to -CD to retrofit cruise. Fitted new BCM, used forscan to delete all keys, program 2 new keys and do module initialisation. Now the car runs but with wrong config (from donation car).
Used IDS, Module programming, Retrieve Ford Etis Asbuild data....won't work. Neither when I let IDS download the asbuild nor with selecting my modded asbuild (cruise activated).
Both times I get the same error, as showed in picture.
Hovervan
Postby loot » Thu Jun 29, 2017 10:37 am
If you have ids why can't you initialize the bcm and keys using it?
Usually the first thing i check if it won't program is usb cable.
However, it is common for ids to show the fault yours showed but still have worked, the program refers to the speedo cc data.
Try again and read the config after it to see if it has actually loaded.
Also look for the cc light with ignition on, that's on the speedo :-)
07 350 170ps
Ids map here
loot
Postby Hovervan » Thu Jun 29, 2017 10:43 am
Thanks loot, I was at the car now and it seems you are right...
First I did load the config from car, same error, but it downloaded the EXACT config of my car. VIN is also correct. Lights etc. now are working. It seems the file was installed correct yesterday.
Then I modified to cruise on, uploaded to car, again error.
but now CC light goes on when I turn ignition.
It seems to program correctly but refuses to confirm this :mrgreen:
Hovervan
Users browsing this forum: metalworker0, sentenza13
