fuse box
fuse box
Postby leemac » Sun Nov 13, 2005 5:52 pm
does anyone know if there are any more fuses other than the ones in the main fusebox?
leemac
Postby MrMPuk » Sun Nov 13, 2005 6:17 pm
Why, what's not working?
Postby leemac » Sun Nov 13, 2005 7:41 pm
you name it
leemac
Postby MrMPuk » Sun Nov 13, 2005 7:46 pm
Does nothing work?
Postby leemac » Sun Nov 13, 2005 8:03 pm
just daft things ,lights stop working,then the horn ,i've changed the fuses and everything was fine but then it started all over again.i've followed the loom and as far as i can see it's in good order .
leemac
Postby MrMPuk » Sun Nov 13, 2005 8:07 pm
Wont be fuses, prolly a bad earth.
Postby Nighthawk » Sun Nov 13, 2005 11:01 pm
Can you be any more descriptive of the concern?
The lights and horn are on different circuits.
The earths could be an issue, but it normally does some strange things with an earth fault.
If you want to check the earths and possibly undo them and clean them on the 2000---> transit I'd start at
The Battery, remove the NEG lead and clean the terminal end and the end that connects to the floor, also pay particular attention to the 350A fuse as they crack causing total loss of electrics.
With that lead still off....
There are earths for the main dash loom at either side of the vehicle above the front suspension top mountings.
And also 2 more earth points on the bulkhead by the side of the heater box, look up by the clutch pedal and you'll see them near the air bag control module.
On an aside note,
The horn units are prone to failure on the earlier 2000 series because they fill with water, and the light switches are known to throw their hand in.
Nighthawk
Postby leemac » Tue Nov 15, 2005 8:42 pm
checked all the earth leads and found the one under the dash had worked it's way loose,so i give it a clean and put it back on problem solved thanks fellas
leemac
Postby MrMPuk » Tue Nov 15, 2005 8:47 pm
Said it was earth originally!
Users browsing this forum: Trev_
