Question for experts.
Postby italian transit » Mon Nov 14, 2005 12:47 pm
Good day for all, there is between of you an expert of Transit mk1 and mk2 that it can
know if the front windshield of the mk2 can be mounted on mk1 :roll: ?Thanks to all. :D :D
italian transit
Postby MrMPuk » Mon Nov 14, 2005 1:30 pm
I believe they can mate.
Postby Luke » Mon Nov 14, 2005 1:37 pm
yes! they are the same window and frame only the rubber is different!
Postby italian transit » Mon Nov 14, 2005 1:43 pm
Are you sure?My god i wanted only the rubber............please you help to wanted this :cry: :cry: ?In Italy nothing is not found......... :cry: :cry: :cry:
italian transit
Postby MrMPuk » Mon Nov 14, 2005 1:46 pm
The rubber will fit, but are of a slightly different design.
Postby italian transit » Mon Nov 14, 2005 1:53 pm
Are you sure???Because I have found a mk2 from italy, that has the glass and the
rubber..........I would not want to buy it if it does not mount to us! :roll: :roll:
italian transit
Postby madmark » Mon Nov 14, 2005 5:11 pm
the rubber should fit the mk1 but are difrent in the corners, but dont forget the mk1 and mk2 are the same body apart from front wings! :D
Postby FredTransit » Mon Nov 14, 2005 7:52 pm
Yes, glass and rubber (with a small diference, some call the Mk2 rubber the one with ears) are exactly the same. One will fit the other, but do not fit a new rubber with a second hand screen, it can easily break it.
FredTransit
Mk2 Trannyist
Postby italian transit » Mon Nov 14, 2005 9:57 pm
Fred therefore if I buy glass and rubber of mk2 mounts perfectly on
mk1? :D :D :)
P.S:Sorry for my English imperfect..........I hope that you understand to me!!! :oops: :oops:
italian transit
Postby FredTransit » Tue Nov 15, 2005 9:47 am
Yes Mk2 screen and rubber will fit the Mk1, but make sure they are both either new or both second hand whereever you get them from.
FredTransit
Mk2 Trannyist
mk1/2 window rubbers
Postby pete_the_4x4 » Wed Nov 16, 2005 1:25 am
penso che misura voi possa dovere assettare i angoli
(i think) :twisted:
if you think my van is dirty you should see my pants
pete_the_4x4
Postby italian transit » Wed Nov 16, 2005 11:02 am
that what means to arrange :shock: !I must dull the angles,you creeds that to my mechanic a similar job succeeds!Thanks still to all.................................if you come in vacation to Rome you write to me, I offer myself like tourist guide :D :D
italian transit
tranny
Postby pete_the_4x4 » Wed Nov 16, 2005 7:56 pm
can you tell how board i was last nite???
pete_the_4x4
Return to Mk 1 & 2
