help help s**t
help help s**t
Postby pike » Mon Nov 14, 2005 1:15 pm
itsme again thought id get underneath fit the cross meber and prop now im stuck mk2 wont fit mk3 crossmember wont fit the mk2 1 knocks of the gearbox and its 2 low mk3 1 brackets dont fit the holes thinking og grinding of mk3 brackets and makeing me own help thanks
pike
Postby MrMPuk » Mon Nov 14, 2005 1:29 pm
Have you tried doing Image in you original post?
Postby Luke » Mon Nov 14, 2005 1:30 pm
mate you could do with replying to the other post you made on this - without searching back i forget which box you have fitted mt75 or type 9??
on mine i welded the brackets on - went on no probs!!
although with type9 i cut the crossmember in half and bolted it back with a welded in plate so i didnt have to take the engine out to get the gearbox out - if you know what i mean -i can put up a photo if your unsure!!
:D
Postby pike » Mon Nov 14, 2005 2:25 pm
hi all sorry just read last posts its a mt 75 ive cut the brackets of mt75 crossmember , cut brackets of old crossmember and am in prosse of welding them on mt75 mem as old 1s r high 1 side and short other will fit then thanks
pike
Postby pike » Mon Nov 14, 2005 5:06 pm
u no u said the props only inch longer . i must have done something wrong becouse mines about 8in 2 long if u can tell me how 2 uplaod pics ill show u ?
pike
Postby jay » Mon Nov 14, 2005 5:18 pm
if you look in the gallery it tells u how to upload pics.go by the ones fred wrote.(its in dipstick language)
mk1 connect tourneo
jay
Postby Luke » Mon Nov 14, 2005 5:41 pm
pike wrote:u no u said the props only inch longer . i must have done something wrong becouse mines about 8in 2 long if u can tell me how 2 uplaod pics ill show u ?
yeah mt75 prop is shorter i was on about type 9 one!! :lol:
Postby pike » Mon Nov 14, 2005 5:48 pm
the mt75 prop of mk3 is about 8in longer than my mk2 1 thats when fitted underneath
pike
Postby Gunslinger » Mon Nov 14, 2005 5:50 pm
the rear two mounting holes (1 each side) on the mk3 crossmember will fit the mk2 van, it is the front ones that wont, you have a couple of options
1) weld the front mounting points to the chassis
2) drill new holes in the chassis and mount plates with nuts on them inside the chassis rail
3) cut the front mounting points off the mk3 crossmember and do the same with the mk2 ones and swap them, and weld them back together when you have it all lined up (kind of like extensions or outriggers)
Gunslinger
Postby pike » Mon Nov 14, 2005 6:06 pm
pike
Postby Luke » Mon Nov 14, 2005 6:12 pm
pike wrote:the mt75 prop of mk3 is about 8in longer than my mk2 1 thats when fitted underneath
sorry yeah i do know what im talking about :oops: ............ honest!! :lol:
the mt75 box is shorter - yes the prop is longer!
the mk3 wheelbase is about 1" longer if you take the mk3 mt75 prop to specialist they will be able to shorten it if you take both props you should be able to have one made to fit perfect!! :D
Postby Gunslinger » Mon Nov 14, 2005 6:13 pm
yup .... wrong prop
for my mk2 lwb, i got a mk3 lwb prop, but from my searching around the best option for the length to be correct is a mk3 lwb (standard length not extended) flatbed (dropside) or tipper as these seem to be simliar lengths to the mk2
just one other thing mine is a twin wheeler, and so was the donor vehicle, single wheel lwb vans seem to be of all sorts of different wheelbases :? so try and stick to like vehicle types if you get what i mean
Gunslinger
Postby Luke » Mon Nov 14, 2005 6:15 pm
Gunslinger wrote:yup .... wrong prop
just one other thing mine is a twin wheeler, and so was the donor vehile, single wheel lwb vans seem to be of all sorts of different wheelases :?
is this on a lwb or swb :?
Postby Gunslinger » Mon Nov 14, 2005 6:18 pm
mines a lwb luke (and the prop i have came from an 89 / 90 mk3 twin wheeler)
like i said, tippers are the best bet for a matching prop length
EDIT! ... dam it this topic is spread over 3 posts ... i have already answered the issue of the centre bearing mounting position needing relocating ....... can someone merge the topics and tidy it ?
Gunslinger
Postby pike » Mon Nov 14, 2005 6:20 pm
mines a swb motor home done the cross member made 1 out of the 2 got both props but the petrol 1 of mk2 is a lot thinner carnt i just take uj off gear box end ove mt75 prop and swop ends with petrol end ?
pike
