My Mk7 v2
My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 9:57 pm
Decided to re-do my project thread to cut put the pictures in properly and cut out some of the waffle :lol:
Last year, I needed a van so bought this
2006 2.2 280 SWB m/r 85ps on 140k
Image1930567_10156741903300492_5163795392355461090_n by danbougourd, on Flickr
Image10013939_10156741903610492_7297680383094192849_n by danbougourd, on Flickr
Image1936528_10156741904060492_5705994066786281920_n by danbougourd, on Flickr
Image1915730_10156741905355492_6349282097945403539_n by danbougourd, on Flickr
I race karts (hence the plate) and at the time was helping out a young lad and although I could fit 1 kart on the roof of my disAstra estate, 2 wasn't happening
Image10413424_10156741907770492_1399606405979156755_n by danbougourd, on Flickr
First job was remove the rear shelving, selling the roof bars and using it to move house
Image13118920_10156970520350492_3929424627974510248_n by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:01 pm
Stuck the old mats I had lying about from my 1st Focus RS
Image10568885_10156741908725492_3518077326372099267_n by danbougourd, on Flickr
Used the hair dryer trick on the plastics to bring them up black again. Worked better than expected, although they are now faded again due to the fact I rarely clean it
Image13343011_10157076466535492_2425940109129653390_n by danbougourd, on Flickr
Headlight bulb went, so upgraded the light. Only cheap off eBay but the difference is night and day
Image13139161_10156977263635492_2908386676366960198_n by danbougourd, on Flickr
Image13179398_10156977263960492_3446632404285648941_n by danbougourd, on Flickr
Image13151517_10156977264145492_7404770992442035079_n by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:03 pm
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:05 pm
As I also sleep in it at the track, one cold November night led me to look at insulation. Ended up buying some foil bubble wrap type stuff that won't sweat and will also keep weight down.
Started with the floor
Image15741056_10158078367405492_7671973689435403966_n by danbougourd, on Flickr
Image15665532_10158078367975492_3299927599763377909_n by danbougourd, on Flickr
Image16299076_10158242780460492_8718930248756270137_n by danbougourd, on Flickr
Then behind the side panelling
Image16388081_10158250187920492_3252875063974633147_n by danbougourd, on Flickr
Image16406969_10158250188120492_1622982047881836850_n by danbougourd, on Flickr
Image16265231_10158250188375492_7486408533291797118_n by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:09 pm
Over a year after buying replacement doors that got bent when the mrs didnt back me in properly during the house move, I fitted them
ImageIMG_20170725_190944 by danbougourd, on Flickr
Whilst I was at it, I set about changing the high level brake bulb, but there was a problem
ImageIMG_20170725_174337 by danbougourd, on Flickr
Found what looked like the bulb holder inside the bottom of the door
ImageIMG_20170725_174348 by danbougourd, on Flickr
Had at some point been snapped away from the lense so I broke out the glue gun and fitted a new bulb. Was a little bit pleased with myself as was just about to spend £20 on a replacement unit :D
ImageIMG_20170725_175209 by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:12 pm
More insulation going in during the small amount of free time I have at the moment with a wedding now less than 2 weeks away
Image20479896_10159260121220492_1649367927185543303_n by danbougourd, on Flickr
Also thought as I've got tonnes of the stuff left, I may as well do against the inner skin, as well as the back of the ply lining
Image20479745_10159260123670492_1208314563023070408_n by danbougourd, on Flickr
Image20525806_10159260124415492_8672291349384220237_n by danbougourd, on Flickr
Image20375945_10159260124805492_4245018931358226614_n by danbougourd, on Flickr
Plus another little addition from my old RS. Nobody wanted to buy it so shame for it to sit under my bed gathering dust :D
Image20525562_10159260120805492_4508294448094922393_n by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Tue Aug 01, 2017 10:16 pm
Main plans atm are to finish the insulation and then move onto the outside as I'm starting to get a lot of arch bubbling that seems to be spreading alarmingly quickly :shock:
Toying with the idea of installing mains hookup and a couple of plugs inside for when I'm at the track. Could also do with replacing the factory headunit for something with bluetooth and ipod connectivity.
This is the only forum I use that seems to still get a lot of traffic as everything else just seems to have moved over to facebook which is a huge shame, so I will do my best to keep this updated
dantranvan
Re: My Mk7 v2
Postby dantranvan » Fri Aug 25, 2017 5:18 pm
£3.99 aux in mod fitted
ImageIMG_20170825_162700 by danbougourd, on Flickr
My rubbish fitting guide can be found here http://fordtransit.org/forum/viewtopic.php?f=5&t=181730
dantranvan
Re: My Mk7 v2
Postby dantranvan » Sat Aug 26, 2017 4:12 pm
Time for a bit of pikey paintwork
ImageIMG_20170826_113836 by danbougourd, on Flickr
ImageIMG_20170826_120208 by danbougourd, on Flickr
ImageIMG_20170826_120650 by danbougourd, on Flickr
ImageIMG_20170826_124405 by danbougourd, on Flickr
ImageIMG_20170826_133118 by danbougourd, on Flickr
ImageIMG_20170826_150836 by danbougourd, on Flickr
Far from perfect as I tried rushing it towards the end but atm I'm more interested in sorting out the little rusty bits before they turn into holes and the winter weather is upon us. Once we get to spring I'll go round the bits I'm not happy with to a better standard
dantranvan
Re: My Mk7 v2
Postby dantranvan » Sun Sep 03, 2017 1:28 pm
Picked up a donor front bumper for £20 so I have one to chop up to make a debadged grille.
In addition to that, I also fancy some banded steelies and a suspension drop, but as always, it will depend on whether I find other things to spend my money on
dantranvan
Re: My Mk7 v2
Postby dantranvan » Fri Oct 06, 2017 9:01 pm
Only taken me a month to make a start. Will be genuinely surprised if it's on the van this year :lol:
ImageIMG_20171006_143159 by danbougourd, on Flickr
ImageIMG_20171006_143348 by danbougourd, on Flickr
dantranvan
Re: My Mk7 v2
Postby dantranvan » Thu Nov 23, 2017 10:11 pm
dantranvan
Re: My Mk7 v2
Postby Kenton » Fri Nov 24, 2017 10:57 am
Great thread and nice little tutorial on the aux lead mate. Do keep the updates coming! How did the de-badge of the front grill go?
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Re: My Mk7 v2
Postby Shaun306 » Fri Apr 13, 2018 6:57 pm
Any updates
Shaun306
Re: My Mk7 v2
Postby dantranvan » Tue Jun 12, 2018 9:48 pm
Been mad busy, hence the lack of updates. Got quite a bit to sort out in the next couple of weeks, mainly rust :oops:
Both of the rear wheel arch tubs need some work, all 4 arches are showing signs of bubbling and a few tiny spots along the bottom of the body and the roof need treating and painting. I then need to get the grille finished and fitted. Made some good progress fitting out the back, but that all came out tonight in preparation for rust repair so will update as it goes back in and will hopefully be neatened up to as it was a bit thrown together in a hurry.
dantranvan
