ignition live
ignition live
Postby trannydenz » Tue Nov 14, 2017 10:39 pm
I've fitted the 12 volt and 240 volt into my day van but stuck on how to fit the battery to battery charger under the passenger seat. it's a euro 6 custom limited and was thinking is there an ignition live under the seat somewhere like tapping into the heated seats to save going to the fuse box somewhere instead or is this a daft idea?
trannydenz
Re: ignition live
Postby trannydenz » Wed Nov 15, 2017 10:51 pm
I've found a ignition live under the passenger seat what powers the heated seats, is it safe to use this if I tap into it before the relay/plug, with the ignition on its showing 12.2 volts and when start up its showing 14.4. it's to wire in ctek d250sa, there's loads of info for vw,s on the net but not much for transits
trannydenz
Re: ignition live
Postby richbee » Thu Nov 16, 2017 1:36 pm
There's loads of information in the Ford BEMM document, which you can download - loads of stuff, but it will probably be in there somewhere!
http://www.etis.ford.com/bemm/bemmSelectionForm.do
richbee
Re: ignition live
Postby marianosik » Mon Nov 11, 2019 7:42 pm
have you found good ignition live for CTEK C250SA?
marianosik
Return to Transit Custom
Users browsing this forum: FrankMCN
