Evening, thought it was time for a small update.
I've been having running issues ever since I messed with the coils and custom loom, I've had a miss fire that j just couldn't pin down, I was almost adamant in telling myself it wasn't spark plugs and with this I ended up changing the tps, airflow meter, and a combination of new/old plug leads as everytime I've had the inlet off the plugs looked in good condition.
Many hours of googling and the general common fault was coming back and pointing towards plugs
At first glance a set of plugs was looking at nearly £76
(£11 each) but after a bit of shopping around I got them for £28, fitted on Tuesday found a plug had cracked in half and now she runs and drives near on perfect, just a slight hesitation on part throttle that I need to iron out
I've also gotten round to fitting the new lower front springs, new discs/pads and I've also refurbished a spare set of callipers. The discs are the bigger 270mm from the 6stud smileys so makes for a nice factory upgrade.
I've also finished tinting the rest of the sliding windows too
I've also picked up a tailgate from a mate at the squires fordmeet for the trailer project as I needed just the glass and top hinges, the tailgate is I real poor condition but is good enough for me to chop/mock up a lot of the opening front end
As usual a load of pics
