Ford Transit MK7 2.2 tdci diesel leak, need seal info
Postby Danbek1969 » Wed Jan 24, 2018 11:06 pm
Hi
I was wondering if anyone had the specific measurements for the copper rings for the Pressure Sensor and the Pressure Relief Valve?
Ford here in Norway doesnt sell either of em new as a standalone part so buying seals isnt possible either.
Anyone have the correct measurements so I can buy them at my local fittings store?
Best Regards Daniel :)
Danbek1969
Re: Ford Transit MK7 2.2 tdci diesel leak, need seal info
Postby andz327 » Wed Jan 24, 2018 11:19 pm
Danbek1969 wrote:Hi
Can't you measure your own
andz327
Postby v8dave » Wed Jan 24, 2018 11:50 pm
Don't remove them unless there is a problem with them.
Actually, thinking about it the pressure relief valve has a special shim and I don't remember it being copper.
and having check my copy of etis, ford make no provision for removing the pressure sensor - if it fails you replace the fuel rail.
v8dave
Postby Danbek1969 » Thu Jan 25, 2018 8:26 am
v8dave wrote:Don't remove them unless there is a problem with them.
There is a leak so I have to fix it. My car is running a bit groggy and so I have to atleast fix that before I try anything more.
Anyone have a photo of the seals? :)
Danbek1969
Postby v8dave » Thu Jan 25, 2018 7:36 pm
Danbek1969 wrote:There is a leak so I have to fix it. My car is running a bit groggy and so I have to at least fix that before I try anything more.
What ? at both end of the fuel rail ?
Some idiot must have removed the sensor and valve and not refitted them properly.
I did a quick search on google.
First page of images ( didn't even scroll down ) lots of fuel sensors available.
Looks like they have an integrated face seal, so NO washer.
Unfortunately there is no published info from ford on how to fit the sensor.
Should be easy to google.
There is a how to for changing the prv viewtopic.php?f=18&t=164180
The missing info is that you fit the prv to 30 Nm torque.
Then you mark a line on the valve and rail.
Then you loosen and retorque the valve to 172 Nm.
The lines must now be at least 3mm apart.
The pipe connector on the valve is done up to 20 Nm and be careful as they appear to be made from toffee.
v8dave
Postby andz327 » Thu Jan 25, 2018 11:22 pm
Like 8v said integrated face sealImage
andz327
Postby v8dave » Fri Jan 26, 2018 1:02 am
Part of what I do at work is sensor technology related.
I'd actually prefer to see the primary seal before the thread with the ring indicated as a secondary seal.
v8dave
Postby Danbek1969 » Fri Jan 26, 2018 1:04 pm
Thanks for the replies fellas. I have fixed the leaks now :)
Danbek1969
Postby v8dave » Fri Jan 26, 2018 7:27 pm
And would you care to enlighten us as to how that was done ?
v8dave
Postby davyjcb » Fri Jan 26, 2018 7:56 pm
I got1 in that had been over tightened it would not seal even with a new valve,the owner did not want a new rail fitted so I put a tiny among of locktight hydraulic seal on the prv after cleaning and drying both the rail and valve with brake cleaner and compressed air if you are going to try this
AS ALWAYS CLEAN CLEAN CLEAN
Dry all components
Only use enough sealant to fill the root of 2/3 treads
Apply 1/2 way up the threads ,too close to the tip and sealant can get into the rail
Allow adequate cure time
AND FINALLY F**K HELP YOU IF YOU HAVE TO TAKE IT OUT
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby v8dave » Fri Jan 26, 2018 8:33 pm
Which loctite ?
The thread sealants are not necessarily strong.
Have to agree with the cleaning, can't be too clean.
v8dave
Postby davyjcb » Fri Jan 26, 2018 9:26 pm
542 hydraulic seal....locktight original not the cheap generic crap
davyjcb
Postby v8dave » Fri Jan 26, 2018 9:32 pm
davyjcb wrote:542 hydraulic seal....locktight original not the cheap generic crap
Supposed to be medium strength, needs approx. 15Nm to undo it ( on an M10 thread from memory )
v8dave
Postby davyjcb » Fri Jan 26, 2018 11:39 pm
that would be correct so that then becomes the 172 nm plus the extra 15 nm that the lock tight adds to the equation not forgetting that the 172 is a dry torque so the sealant will put it over anyways plus the heat = hard to remove
davyjcb
Postby davyjcb » Fri Jan 26, 2018 11:45 pm
If you've got a dry torque and you put liquid sealant on it will attain a higher torque for a given setting because of the lubricating effects of the sealant used before it has cured
davyjcb
