Back with a mk7 this time!
Re: Back with a mk7 this time!
Postby blue estate » Sun Feb 04, 2018 4:22 pm
If that's the EGR leaking just bypass it :wink:
blue estate
Postby dirtydog » Sun Feb 04, 2018 4:39 pm
It's the oil cooler.
Sump plug is leaking as well, needs a new sump really as the threads are chewed up and has a couple of weeps around it
dirtydog
Postby blue estate » Sun Feb 04, 2018 4:45 pm
dirtydog wrote:It's the oil cooler.
3 birds with one stone job then sump oil cooler and oil change at same time
at least it's leaking water out side and not oil in to water :wink:
blue estate
Postby dirtydog » Sun Feb 04, 2018 4:52 pm
Yep, I did check the oil soon as I noticed the coolant going down every few days.
it's due a service anyway, guess what I'll be doing when I'm "off work" over half term :lol:
dirtydog
Postby blue estate » Sun Feb 04, 2018 5:08 pm
dirtydog wrote:Yep, I did check the oil soon as I noticed the coolant going down every few days.
When's half term ?
blue estate
Postby dirtydog » Sun Feb 04, 2018 5:37 pm
Week beginning 12th February
Just ordered the modified oil cooler and a new sump from transit parts
dirtydog
Postby blue estate » Sun Feb 04, 2018 5:38 pm
dirtydog wrote:Week beginning 12th February
Goodie quiet roads up to London :D :D :D
blue estate
Postby bambi mk 1 » Sun Feb 04, 2018 5:55 pm
dirtydog wrote:
Also found where all my coolant has been disappearing...
Its only the o ring thats leaking :wink: Remove the 8mm headed bolt and the adaptor and put some sealer on it and refit ,will be as good as new :)
bambi mk 1
Postby dirtydog » Fri Apr 06, 2018 3:53 pm
I managed to get the plastic housing and new oring for a few quid on eBay so that's the coolant leak sorted 8)
dirtydog
Postby dirtydog » Fri Apr 06, 2018 4:58 pm
Replaced my broken seat base today
dirtydog
Postby blue estate » Fri Apr 06, 2018 6:05 pm
dirtydog wrote:Replaced my broken seat base today
Time to lose some weight Adam :wink: :lol: :lol: :lol:
blue estate
Postby dirtydog » Fri Apr 06, 2018 7:16 pm
You reckon? :shock: :oops:
dirtydog
Postby blue estate » Fri Apr 06, 2018 7:21 pm
dirtydog wrote:You reckon? :shock: :oops:
blue estate
Postby ned » Fri Apr 06, 2018 8:01 pm
No more rocking and Rollin while driving :lol:
Have you done the wheels yet :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dirtydog » Fri Apr 06, 2018 8:33 pm
ned wrote:No more rocking and Rollin while driving :lol:
No not yet :lol: Have cleared it with my mate that I can store a set of wheels in his shed for now, so the plan is fit the alloys and store the steelies
dirtydog
