What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby birdie » Thu Feb 08, 2018 12:02 am
Are they easy enough to wire up?
mk7 T350 FWD towing van
birdie
Postby andz327 » Thu Feb 08, 2018 12:07 am
ned wrote:
squirrel93 wrote:
ned wrote: no, I had to leave it at a job cos the evil thing won't go in gear :roll: so after some shouting at it I walked off :? Kinda miss it not being outside :( :cry: N
I have the selector from mines complete if you want it posted ?
If it makes you feel better the mk6 ate the clutch today , it’s booked in for tomorrow
Ay up are kid, how much do you want for the selector :?: its working again for now but how long for is the question, it seems I'm having to cover it in wd40 every other month these days :roll:
Just order a new front bearing as that's whining like a 2 year old, these trusty old vans needing parts eh, there not fit for purpose N
No the new bearing is it Ned
andz327
Postby ned » Thu Feb 08, 2018 12:51 am
andz327 wrote:
No the new bearing is it Ned[/quote]
Luckily not Mr Andz Sir t'is the side I put the new spring on, I have the part just not had the time to do it :roll: bloody work keeps getting in the way, how's your new engine going :?: :D N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Airthies » Thu Feb 08, 2018 1:13 am
What's the thread on the brake pipe fittings on these vans? Metric or imperial?
Just ordering up some bits prior to the mot.....
Sent from my anu5 using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Thu Feb 08, 2018 1:15 am
ned wrote:
Luckily not Mr Andz Sir t'is the side I put the new spring on, I have the part just not had the time to do it :roll: bloody work keeps getting in the way, how's your new engine going :?: :D N[/quote]
andz327
Postby andz327 » Thu Feb 08, 2018 3:34 am
andz327 wrote:
[/quote]Aye the new old engine is good mate, just wish i had the work to go with it mate
andz327
Postby Brains_transit » Thu Feb 08, 2018 5:52 pm
Found the problem why it wouldn't turn over the glow plug live had chafed where it follows the shape of the engine and was earthing :x the main starter earth is either a bad connection or water had corroded it internally but I can drive it with a jump lead from the starter bolt to the front arch :lol:
Brains_transit
Postby Airthies » Thu Feb 08, 2018 6:25 pm
Brains_transit wrote:Found the problem why it wouldn't turn over the glow plug live had chafed where it follows the shape of the engine and was earthing :x the main starter earth is either a bad connection or water had corroded it internally but I can drive it with a jump lead from the starter bolt to the front arch
The engine earth cable corrosion is what I put down to why my van was frying electronic modules for a while. Both ends of the earth seemed ok but the internals of the cable were shot!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby motorman116 » Thu Feb 08, 2018 6:36 pm
Fitted 2 x antiroll bar D bushes and N/S/R Brake caliper... Blasted parking brake lever kept on sticking on :( and no more knocking from the front :D
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby dirtydog » Thu Feb 08, 2018 9:59 pm
Airthies wrote:What's the thread on the brake pipe fittings on these vans? Metric or imperial?
They're metric, I bought some at the weekend from Halfrauds
dirtydog
Postby Airthies » Thu Feb 08, 2018 10:03 pm
Cheers DD got an assortment box ordered so I'm gonna have plenty now.
It's mostly metric with a couple of imperial fittings which will be handy when I come to do the mini (If I ever get the time...)
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Brains_transit » Thu Feb 08, 2018 10:21 pm
Yeah designed to fail with the wire at the chassis leg on line with the waterfall when it rains
Brains_transit
Postby Pete.s » Thu Feb 08, 2018 11:23 pm
Fitted the steel bulkhead and me new LED' lights in the back
If its got T*ts or Tyres yr in for Trouble :lol:
Pete.s
Postby HuMpH » Thu Feb 08, 2018 11:44 pm
Nice ..which leds you got ? They’re not the strip type that cut to length are they ? Can’t tell on phone lol
When they go out are they completely off or does 1 stay very dim.
Never seen those fitted panels over cab before either, very posh
125 T350 Lwb Hitop Rwd now sold.
Mk7 110 T300 Fwd
T-shirts preview Here
HuMpH
Postby ned » Thu Feb 08, 2018 11:45 pm
Pete.s wrote:Fitted the steel bulkhead and me new LED' lights in the back
I always think ford should have fitted a small hatch to access the battery through the bulkhead. N
ned
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
