Yep worked a treat even without the pressure bleeder it requests.
I purged the master cylinder first to get the fluid moving to the ABS pump, then just went through the bleed cycle I think 3 times just to be sure (I had 5lt to play with)
It's a doddle if you've got van jacked up on stands and wheels off
Full brake line replacement and have about 500mm of tube left from 2x 25ft(~7m) rolls of tube to do a LWB Mk7.
The main lines from master to AND were the worst getting them round the back of the engine bulkhead.
Fuel filter off, coolant bottle off. Front headlight out. But all in all not a bad job....
Sent from my anu5 using crapatalk
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
