diff and box oil change
Postby maccavvy » Sat Feb 24, 2018 3:14 pm
couple of questions
what oil grades and amounts are needed
how to drain the box and diff. do they have drain plugs ? is it remove the rear diff case ?? does it have a seal if so
2010 RWD 2.4 tdci 115
cheers guys
Mk8 310 trend FWD and a 5.7 ls1 monaro RWD
maccavvy
Re: diff and box oil change
Postby v8dave » Sat Feb 24, 2018 4:13 pm
Gearbox oil is specified as WSD-M2C200-C
A service refill needs 2.2 litres, from dry you need 2.4 litres.
Axle oil is specified as WSL-M2C192-A
Capacity is 3 litres.
Torque is 50Nm
Torque is 35Nm
Axle oil drain is by removing the rear cover, there is no gasket.
You need to seal it back on with a sealant to WSS-M4G320-A3 ( I can't find an equivalent but Loctite recommend 5910 for this )
The bolts are torqued to 61Nm.
There is apparently a filler/level plug.
v8dave
Postby blue estate » Sat Feb 24, 2018 4:16 pm
v8dave wrote:Gearbox oil is specified as WSD-M2C200-C
Torque is 50Nm
Torque is 35Nm
yes there is and it's handily a 3/8th square :wink:
blue estate
Postby v8dave » Sat Feb 24, 2018 4:28 pm
blue estate wrote:yes there is and it's handily a 3/8th square :wink:
I had not found it in etis when I posted earlier.
The torque for the filler plug is 34Nm.
v8dave
Postby maccavvy » Sat Feb 24, 2018 7:56 pm
where do i get those oils , or is there a common name number ?
maccavvy
Postby v8dave » Sat Feb 24, 2018 10:53 pm
You either spent a lot of money at ford or look the specs up on the oil manufacturers websites.
v8dave
Postby maccavvy » Sun Feb 25, 2018 10:35 am
so e75w90 for gearbox and 75w140 for diff then
thanks for your help guys
maccavvy
Postby knobby1 » Sun Feb 25, 2018 7:19 pm
maccavvy wrote:so e75w90 for gearbox and 75w140 for diff then ...thanks for your help guys
Just be careful with the gearbox oil...some of them foam up and blow out through the box breather, even if they meet the required specs... Had that issue when I changed my gear oil last year, I used a good quality synthetic gear oil and most of it ended up pouring down the side of my gearbox, so I found out what the Mustang guys were using, (Some Mustangs use the MT-82 6sp gearbox)...Among others, they recommend Redline MTL, it's excellent, but expensive.
Postby Jim Archer » Tue Mar 20, 2018 2:18 pm
Is it deffinately 2.4L for a MT82 gearbox? Did mine at the weekend and got 3L in without it coming out of the filler hole.
3L of 'real' Ford stuff from Hendy's was £68 inc the VAT which I thought was quite reasonable given the prices the local factors are wanting. Did spend nigh on £400 on service bits there so there was a bit of discount.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby the dutch guy » Tue Mar 20, 2018 3:52 pm
You sure you put it in the right hole? :roll:
Mk6 SWB TDCI 125
the dutch guy
Postby knobby1 » Tue Mar 20, 2018 8:28 pm
MT-82 6-speed box is 2.4 liters oil capacity for the "initial fill"....2.2 liters for "service fill".
MT-75 5-speed box is only 1.3 liters oil capacity..
Postby Jim Archer » Wed Mar 21, 2018 1:26 am
Hmmm, maybe it is just a fill hole and a level?
No adverse affects thus far, as much as I can tell.
Jim
Jim Archer
