DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby starry » Fri Mar 02, 2018 1:38 pm
Information on Na12ctf if possible please and thank you
Adam
starry
Postby ned » Sat Mar 03, 2018 9:26 am
starry wrote:Information on Na12ctf if possible please and thank you
Adam
Transit 2006-2014, 2.2L CR TC I4 DSL 100PS, Frozen White
VIN Number: WF0XXXTTFXCR83838
Registration Number: NA12CTF
First Registration Date: 01.04.2012
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 24.02.2012
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: 2.2L CR TC I4 DSL 100PS
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.91
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With Medium Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
Brake System - Regenerative
With Full Partition - Steel
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Paint Package
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
With Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
With Cargo Stowage Rail (Mid)
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Self Colour Rear Bumper End Caps
Mid Grey Front Bumper
With Grey Plastic Rear Bumper
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5.5 X 16" Steel Wheel
With Wheel Hub Cap
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Starter - Stop/Start System
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tachograph
With Trip Computer
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Extra Heavy Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
Less Front Fog Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Scoots » Sat Mar 03, 2018 10:04 am
Ford transit dy51ole thanks scott
Scoots
Postby ned » Sat Mar 03, 2018 6:24 pm
Scoots wrote:Ford transit dy51ole thanks scott
Transit 2000-2006, 2.0L Duratorq DI(100PS), Pepper Red (Metallic)
VIN Number: WF0VXXBDFV1C87836
Registration Number: DY51OLE
First Registration Date: 18.10.2001
Primary Features
Build Date: 05.09.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 280S Series
Engine: 2.0L Duratorq DI(100PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.54
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Pepper Red (Metallic)
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-I-C)
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
LH Sliding Side Cargo Door - Low
Southampton Plant Built
Marketing Level 3
Less Header Mounted Package Tray
With Complete Rear Hardboard Trim
With Roof Height Feature Pack 1
With Front Roof Grab Handle
Passenger Lrg Head/Short Arm Mirror
With Passenger Seat Valance
With Driver Air Bag
195/70R 15C LI 100/98 BSW
Any Brand Tyre Vendor
With H/B Sngle.Drv & Dual Pass Seat
With Manual Clutch
With Pollen Filter
With Recirculating Heater
With Radio Pre-Equipment Pack 1
2000NT Series
With Power Point Plug
With Load Compartment Lamp
ned
Postby RHodgett » Sun Mar 04, 2018 12:58 am
Please could you give me details for YC61HXW?
Owner of a 1992 Ford Transit 150 2.5 Diesel Lwb A
RHodgett
Postby PADalesvan » Sun Mar 04, 2018 3:45 am
HI I just bought my first transit , wondering if any of you clever folks can give me some info on it please reg no KY51PZD
cheers
PADalesvan
Postby starry » Sun Mar 04, 2018 9:19 am
Many thanks Ned appreciate it
starry
Postby MadLensman » Mon Mar 05, 2018 10:30 am
If poss, could someone please snuffle up the info on X493XBR when they get a mo please? Thanks in advance!
If it doesn't work, hit it.
If it STILL doesn't work, hit it harder.
If it STILL Doesn't work, get a hammer.
If it STILL Doesn't work, maybe hitting it wasn't such a good idea!
MadLensman
Postby fzrtdizxr » Mon Mar 05, 2018 6:05 pm
hi need details of my newly purchased transit mk6 2.3 pet/lpg reg number gn02nwe with thanks in advance steve
fzrtdizxr
Postby ned » Mon Mar 05, 2018 6:23 pm
RHodgett wrote:Please could you give me details for YC61HXW?
Transit 2006-2014, 2.4L Duratorq (85kW/115PS)
VIN Number: WF0XXXTTFXBJ27978
Registration Number: YC61HXW
First Registration Date: 07.11.2011
Primary Features
Build Date: 03.09.2011
Series: 350E Series
Engine: 2.4L Duratorq (85kW/115PS)
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Air Conditioning:
Territory: (+)"GB"
Minor Features
With High Roof
With Rear Mudflaps
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
Less Diesel Particulate Filter
Less Brake System-Regenerative
With 256° Cargo Door Check Arms
With Magnetic Rear Door Catch
Less Liftgate
Complete Vehicle
Less Sales Badge
Less Trim Pack
Marketing Level 3
Less Dress Up RSO
Less SVO Except Packs
Less SVO Marketing Packs
With Tool Kit
Less Heated Windscreen
Less Cargo Stowage Rack/Rail
Less Running Boards
Less Roof Rack
With Rear Step - Centre
Seat Pack 22
Less Fleet Key
Remote Control Door Entry - 2 Fob
Less Sun Roof
Less Rear Sunroof
Less U/Body Corrosion Protect
With Driver Air Bag
Less Float Mounting
215/75R 16C 116/114
70MPH Engine Governor
Diesel Fuel Cooler
Standard Electric Starter Motor
Dual Mass Flywheel
Less Transfer Case
Less Skid Plates
Less Heater
Less Tripminder Assy
With Tachometer
Thatcham Catergory 1 Alarm System
Less Bluetooth
Ice Feature Pack 5
Less Module/GPS Antenna
Less Telephone
Less Microphone
Electrical Outlet
Less Camera
Less Safe Deposit Box
Less Dual Rear Wheel Pack
Less Wheel Pack
Less Aero Pack
Less Daytime Running Lamps
With Side Marker Lamps
Less Wiring Harness
ned
Postby ned » Mon Mar 05, 2018 6:25 pm
PADalesvan wrote:HI I just bought my first transit , wondering if any of you clever folks can give me some info on it please reg no KY51PZD
cheers
Transit 2000-2006, 2.0L Duratorq DI (75PS), Colorado Red
VIN Number: WF0VXXGBFV1R18482
Registration Number: KY51PZD
First Registration Date: 05.10.2001
Primary Features
Build Date: 20.06.2001
Series: 260S Series
Engine: 2.0L Duratorq DI (75PS)
Drive: RHD FWD
Axle Ratio: 4.54
Territory: (+)"GB"
Paint: Colorado Red
No minor detail available for this one. N
ned
Postby ned » Mon Mar 05, 2018 6:26 pm
MadLensman wrote:If poss, could someone please snuffle up the info on X493XBR when they get a mo please? Thanks in advance!
Transit 2000-2006, Duratorq DI 2.4 (90PS), Diamond White 73
VIN Number: WF0LXXGBFLYE18174
Registration Number: X493XBR
First Registration Date: 08.09.2000
Primary Features
Build Date: 17.08.2000
Series: 350M Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.63
Territory: (+)"GB"
Paint: Diamond White 73
Minor Features
With Medium Roof
With Rear Mudflaps
With Front Mudflaps
LH Sliding Side Cargo Door - High
Genk Plant Build
Marketing Level 3
With Driver Air Bag
215/75R 16C BSW Tyres
With Pollen Filter
2000NT Series
ned
Postby ned » Mon Mar 05, 2018 6:29 pm
fzrtdizxr wrote:hi need details of my newly purchased transit mk6 2.3 pet/lpg reg number gn02nwe with thanks in advance steve
Transit 2000-2006, 2.3L DOHC (145PS), Diamond White 73
VIN Number: WF0LXXGBFL1K70351
Registration Number: GN02NWE
First Registration Date: 15.05.2002
Primary Features
Build Date: 13.11.2001
Series: 1.7-350L Series
Engine: 2.3L DOHC (145PS)
Drive: RHD RWD
Axle Ratio: 5.13
Emission: 2000 EEC (EEC 7)
Territory: (+)"GB"
Interior Fabric: Cordwain Vinyl (B-V
Minor Features
With High Roof
With Rear Mudflaps
With Front Mudflaps
Genk Plant Build
With SVO Application/Label
Marketing Level 3
With Front 2 Way Headrest
With Driver Air Bag
With Single Seat - Driver Only
With Manual Clutch
With Pollen Filter
Standard Duty Battery
Drivers Seat Rechargeable Battery
2000NT Series
With Battery Cut Off Relay
ned
Postby fzrtdizxr » Mon Mar 05, 2018 7:22 pm
hi thanks for that
can i take it from that the lpg isn't factory approved fitting or wouldn't that show on etis
a mate is an royal mail mechanic' apprentised with ford and said they were sent out to an approved fitter for lpg would this show on v5c or etis ?
cheers steve
fzrtdizxr
Postby Zafox » Tue Mar 06, 2018 6:46 am
Any chance someone could check my van for me? MT57GFA. Ta!
Zafox
