Ford Transit 2.5 DI camshaft seal still leaking
Postby transit1160 » Tue Mar 20, 2018 8:17 am
Hello guys,
i need an opinion on my transit oil leak problems. my transit is the mk5 with 2.5DI banana/smiley engine. it has developed major leaks and turns out its coming out from the camshaft seal. i replaced the camshaft seal including the spacer for the seal to seat. i also replaced the o-ring between the camshaft pulley and the spacer. and the leaks stop when on idle and a little revving. however after 10 minutes drive....seems that the seal leaks again but only when driving. if the van is stationary and in idling...its not dripping oil. i have fitted the FEBI made oil seal to the camshaft and it as fitted straight ahead. could the leak come from the fasteners/bolts that holding the intermediate aluminum plate to the engine block? or is it possible excessive oil pressure pushing the oil thru the camshaft seal? really need your opinions on this. thanks in advance
transit1160
Re: Ford Transit 2.5 DI camshaft seal still leaking
Postby dumper » Tue Mar 20, 2018 12:03 pm
I once had similar problem on a loading shovel crank seal pu 3 seals in still the same then one of the oil guys had a go all he did was put blue hylermar on the o ring
Postby cherniy_chack » Tue Mar 20, 2018 8:23 pm
transit1160,I think, the oil seal FEBI is not the best option.
I like the oil seals of VICTOR REINZ.
I do not think that there is high pressure in the lubrication system.
I think that the oil seal itself is incorrectly installed. Perhaps, it is too deeply buried in the nest.
Its plane should be on the same level with nest.
cherniy_chack
Postby transit1160 » Sat Mar 24, 2018 2:43 pm
Dumper - what is blue hylermar. do you have any photo of it?
transit1160
Postby transit1160 » Sat Mar 24, 2018 2:46 pm
cherniy_chack - i really worried with the age of camshaft seal for this vintage transit. i have a new genuine camshaft seal from the dealer and it was made in 2004. well i believe the mechanic install the oil seal too deep until it leans on the camshaft holding plate. is there any method or any measurement in order to fit the oil seal correctly?
transit1160
Postby gotgcoalman » Sat Mar 24, 2018 4:22 pm
Check the shaft for a "witness mark" as to where the original seal used to be.
Use this as a guide as to where the replacement needs to be seated.
Mon chien n'a pas de nez. :shock:
gotgcoalman
Postby cherniy_chack » Sat Mar 24, 2018 5:03 pm
In order not to think about the depth of landing of the oil seal in the socket, it is necessary, together with the oil seal, to replace the camshaft sleeve.
gotgcoalman wrote:Check the shaft for a "witness mark" as to where the original seal used to be.
cherniy_chack
Postby V184 » Sat Mar 24, 2018 8:09 pm
transit1160 wrote:cherniy_chack - i really worried with the age of camshaft seal for this vintage transit. i have a new genuine camshaft seal from the dealer and it was made in 2004. well i believe the mechanic install the oil seal too deep until it leans on the camshaft holding plate. is there any method or any measurement in order to fit the oil seal correctly?
Ive got the proper installer , where abouts are you ?
V184
Location: You're right, V184 is an arsehole with a chip on his shoulder........
Postby transit1160 » Mon Mar 26, 2018 3:23 am
gotgcoalman - yes i have done that but its still leaking. 3 seals been replaced. im guessing the installation is too deep?
transit1160
V184 - do you ship outside UK?
transit1160
Postby transit1160 » Mon Mar 26, 2018 3:26 am
cherniy_chack - camshaft sleeve also been replaced. the initial problem was...its leaking oil when engine on idle. after replaced the seal and sleeve, the problem with leaking during engine on idle solved. but when i drive the transit and on moderate to high rev, its leaking badly. but leak will stop if the engine on idle.
transit1160
Postby V184 » Mon Mar 26, 2018 9:47 am
ive just measured the side of the installer & the seal needs to go 9mm into the front case. Are you sure its the cam seal leaking, if it is it sprays oil over the cam belt
V184
Postby transit1160 » Mon Mar 26, 2018 10:21 am
V184 - yes definitely the camshaft seal leak. not only spray all over the cambelt. but all over the engine also since i removed the cambelt cover
transit1160
Postby V184 » Mon Mar 26, 2018 12:21 pm
ignore the 9mm thats the depth of the installer, i would say if the seals say 12mm there needs to be 3mm (12-9=3) from the front of the seal to the outer edge of the case ? :? :lol:
V184
Postby dumper » Mon Mar 26, 2018 12:56 pm
It’s a long time since I’ve rebuilt a di but from memory to fit the seal all I did was knock the seal into the bore with a large socket dowon to the shoulder in the bore this has been on engine rebuilds I have only ever had to change one cam seal once for leaking and that was a fleet of over 100 vans
