BONNET VENTS
BONNET VENTS
Postby Valsheda » Sun Nov 13, 2005 8:44 pm
HOW EASY IS IT TO CUT THE HOLES FOR VENTS INTO THE BONNET , I REALISE THIS IS A ONE WAY TICKET ONCE YOU START THIS JOB , SO WHAT IS THE BEST WAY TO DO THIS PLEASE ?????
Valsheda
Top Tourneo Owner
Postby Luke » Sun Nov 13, 2005 8:45 pm
be handy if you had a spare bonnet to practice on!!!
:D
Postby Valsheda » Sun Nov 13, 2005 8:50 pm
YES I GUESS IT WOULD :lol: WHAT IS THE BEST WAY TO DO THIS AND WHAT TOOLS FOR THE JOB ??
Valsheda
Top Tourneo Owner
Postby 24vMk2 » Sun Nov 13, 2005 9:30 pm
What type of vent are you fitting?
I've just fitted a set of Ast*a GTE vent into my spare sapphy bonnet for my car, by cutting the astra bonnet and taking the 'hole' that the vent fits into, then, I cut the Sierra bonnet, and welded the 'hole' into it. Skim of filler, looks factory! :D
Most vents the tools you will need are: angle grinder, or if you are carefull, tin snips, if using snips, you need a drill aswell, and some form of sticking the vent in, silkaflex is great for this.
24vMk2
Postby MrMPuk » Sun Nov 13, 2005 9:32 pm
On finished paint work the best thing i've found is a dremel with the small cutting discs, takes a while but you will get no destortion from heat or damage from using things like jigsaws.
Postby jay » Mon Nov 14, 2005 10:40 am
make a template from card first.then put the template on the bonnet to make sure the vent is in the right place and it looks ok.check underneath the bonnet to make sure you are clear of the streangthers.make out the template on the bonnet the cut by dremal/jigsaw/grinder what ever method you find happy with.stick vent in by silkaflex or what ever you want.skim of filler then paint...job done.. BUT TAKE YOU TIME..
mk1 connect tourneo
jay
Postby martinjpainter » Thu Nov 17, 2005 12:07 am
I have some in my Mk2. I did not do them myself, I had a mate do the work. There are quite a few pictures on my we site: http://www.toytow.co.uk
Here's one, sorry about the dust :D
Regards,
Martin John Painter
http://www.mjp.co.uk
martinjpainter
Postby Valsheda » Fri Nov 18, 2005 12:46 pm
HIYA , THANK YOU EVERYONE FOR YOUR HELP AND ADVICE , VERY HELPFULL :D
Valsheda
Top Tourneo Owner
