Hi everyone,
need to change my clutch and flywheel, I think I'll go for a LUK set for around 300 euros and stick with the DMF as it's a 125 PS soon-to-be camper coversion.
I'd like to order all the necessary bits and pieces in advance. Could anyone with access to ETIS give me the part numbers for
- pilot bearing
- crank shaft seal
- gearbox shaft seal
VIN is: wf0hxxgbfh3l83312
Did I forget anything else that's important?
Thanks a lot in advance!
P.S.: Is there maybe a set from Ford or some OEM to replace all engine/gearbox rubber mounts? Fells like my engine moves around much more than it should.
