Clutch pedal problem
Postby Billysal » Tue Jun 12, 2018 12:51 pm
Hi Guys,
got a new issue appeared on my Transit LWB HighTop 2004. When I've been cruising in 5th on the motorway for a while, after I pull off, suddenly all the tension has gone from the clutch pedal. Meaning the effective travel of the pedal is just a few inches from the floor, and the biting point is just of the floor. The rest of the travel of the pedal is loose. So far I've always managed to change gear, although had a couple of instances where I could barely get it into first. After a few minutes it's seems to regain it's tension and work better, although it's never acting optimally, the gears always need a bit of coaxing into place. Is this a common problem? Self-adjusting tensioner? Just want to have an idea of what I'm dealing with before I go to the garage with it, or if it's possible to fix myself.
Thanks!
Billy
Billysal
Re: Clutch pedal problem
Postby knobby1 » Wed Jun 13, 2018 4:39 am
This is sometimes a symptom of air in the system or possibly...and more likely...a worn out clutch and/or a dying DMF.
Postby Billysal » Wed Jun 13, 2018 10:38 am
Hmm, hope it's not the DMF!
Billysal
Postby goldcoast » Thu Jun 14, 2018 12:57 pm
On a Mk7 that would be the master cylinder failing.
2000 Mk 5 RWD 2.5 TDI LWB Manual 5 High Roof White
1997 Mk 5 RWD 2.5 TDI LWB Automatic Mid Roof White
+ previously 2008 Mk7 LWB T350 6 speed High Roof
:lol:
goldcoast
Postby andz327 » Thu Jun 14, 2018 3:52 pm
Billysal wrote:Hmm, hope it's not the DMF!
goldcoast wrote:On a Mk7 that would be the master cylinder failing.
He's lucky it's a mk6 then.......
andz327
Postby andz327 » Thu Jun 14, 2018 3:54 pm
knobby1 wrote:This is sometimes a symptom of air in the system or possibly...and more likely...a worn out clutch and/or a dying DMF.
+1
andz327
