bigjohnthomas wrote:We have had those in Lincolnshire for weeks
I got one last month from north moss turnip testing station turnip lane Lincolnshire
Mike wrote:paul2012 wrote:
Not are you only fitting a HID bulb but also the ballast & associated wiring for them too.![]()
It states
"It is not permitted to convert existing halogen headlamp units for use with HID bulbs. If it is clear that such a conversion has been carried out, rather than replacing the entire unit with one designed and approved for use with HID bulbs, the headlamp should be rejected."
It effectively also rules out HID projector kits fitted to halogen headlamp units too.
What is being “converted”? The wiring and the ballasts aren’t a “conversion” to the headlamp unit. As I’ve already said, swapping a bulb isn’t “converting”. We all know what they mean, but they’re not saying what they mean, which makes it awkward if someone appeals an mot failure. It needs a case to be taken to court to clarify, but afaik it’s never happened?
