MK1 LWB Twin wheeler : change the diff or the axle ?
Postby Greg L. » Sun Oct 07, 2018 8:14 am
Hello,
I have a MK1 LWB twin wheeler with 5.86 ratio (maybe even more) and it's not suitable for what I want to do with this van.
I wish I could go for a 4.11 diff. I've thought about several options and I have a lot of questions :
1. Swap the whole rear axle from a single wheeler LWB MK1 or MK2, but it appear they have Timken rear axles. Have single wheeler Salisbury rear axles ever been fitted on LWB MK1/2 Transits ?
2. Find another diff for my rear axle, but can't tell which is the lowest one I can get and if I can find it easyly
3. Swap the internals from a Timken rear axle. Is it possible ?
4. Swap a rear axle from a later RWD Transit. I guess it must be as complicated than fitting a Timken rear axle and implies a lot of work.
Can anybody help me ?
Greg L.
Re: MK1 LWB Twin wheeler : change the diff or the axle ?
Postby Luke » Sun Oct 07, 2018 1:08 pm
i have converted my mk1 twin wheeler using a mk4/5 5 stud single rear wheel axle with a set of weller wheels it fits inside the rear arches
i had to weld on new spring and shocker mounts to the axle to make it fit
i also changed the front to mk2 5 stud disk brake hubs - they are a straight swap
Postby Greg L. » Sun Oct 07, 2018 5:30 pm
Thanks Luke ! Good news about the front hubs.
So, I worked on my MK2 FT80 van today and surprisingly, it has a Salisbury / G-Type rear axle. So I guess I can swap the diff internals between my MK1 twin wheeler and my MK2. Can anyone confirm this ?
Greg L.
Postby PIO » Wed Oct 24, 2018 4:13 pm
Fitted a Mk5 Axle to mine, 4.63FDR - Still a bit too high in my opinion.
PIO
Postby Greg L. » Thu Oct 25, 2018 1:23 pm
What did you have to do to make it fit ?
Greg L.
Postby Ralph.9 » Fri Oct 26, 2018 7:19 am
I think I have one 4.63 CWP for a twin wheel axle somewhere.
Ralph.9
Postby Greg L. » Fri Oct 26, 2018 8:23 am
Still interested, Ralph ! ;)
Please PM me with all the details.
Greg L.
Postby Ralph.9 » Sat Oct 27, 2018 8:00 am
Ok, I will look for it on Monday when im at my storage unit.
Ralph.9
Postby PIO » Wed Oct 31, 2018 3:26 pm
Had to move the spring saddles in a bit. Cut them off and re welded and used a jig from my Mk2 axle to make sure all was ok. Bolt in job after that
PIO
Return to Mk 1 & 2
