Help needed with 2012 2.2tdci wiring and coolant pipes
Postby Longers91 » Thu Oct 11, 2018 9:39 pm
Hi all,
Bought my old work van that has been off the road for a year. It turns out that bits have been removed/missing etc
Does anyone have a diagram of the coolant hoses, some are missing from the right hand side, from expansion tank and engine, ive uploaded a pic
Also wires are unplugged and earth lead cut in battery compartment, anyone a picture of where all the wires go? Also any mk7 ive had has been twin battery, there only seems to be wires for 1 battery
Thanks for any info
Longers91
Re: Help needed with 2012 2.2tdci wiring and coolant pipes
Postby Altransit » Thu Oct 11, 2018 9:51 pm
That was originally a twin battery setup that you have there, because you have that big grey relay fitted, which connects the batteries when starting/running. That relay is replaced with a solid busbar on a single battery setup.
Apart from that it's a right mess :!: :oops:
Postby Longers91 » Fri Oct 12, 2018 7:23 am
What way does the earth lead go thats cut? Would it just have a jumper that goes to both batteries? And the positives where does the missing positive for the 2nd battery come from? Also whats the black and green plug go to and the small back single wire connection?
Suppose if anyone has a photo if there connections it would help :lol:
Longers91
Postby Altransit » Fri Oct 12, 2018 9:03 am
The earth lead simply connects both negatives together, then carries on round the front of the battery bay, finally connecting to the front right hand seat base fixing bolt.
Postby Longers91 » Fri Oct 12, 2018 10:18 am
Thanks, where does the positive wire from the 2nd battery connect to on that fuse panel?
Cant find a decent pic on Google anywhere
Longers91
Postby Altransit » Fri Oct 12, 2018 4:54 pm
One connects to the stud on one side of the relay, the other connects to the stud on the other side, one top, one bottom. I'll try and find a pic of mine to upload.
Postby ned » Fri Oct 12, 2018 5:17 pm
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Longers91 » Fri Oct 12, 2018 6:50 pm
Thanks for the help everyone, ill get another look on monday, hoping to get the van sorted cheap and easily and start using it, £700 for a 2012 van isn't bad surely lol
Longers91
Postby Punto443 » Fri Oct 12, 2018 8:35 pm
If it’s a euro5 it’ll have battery monitoring doodahs on the negative terminals too.
And looking at the pics it is a E5. Rwd2.2 and the look of the fuel filter :wink:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby v8dave » Sun Oct 14, 2018 12:45 pm
Assuming the 2.2 rwd is not too different to the earlier 2.4 rwd.
Normal 2.4 rwd has a hard plastic hose from the expansion tank to the top radiator on the drivers side, which you appear to have.
From the side of the thermostat housing a rubber hose about an inch in diameter goes to the bottom stub on the expansion tank.
The little stub on top of the thermostat housing has a small rubber hose that goes to the stub at the top of the expansion tank.
The elbow stub on the front of the thermostat housing has a rubber hose that goes down to the bottom of the radiator.
I would take the expansion tank off the van and clean it out, I'd be suspicious of how rusty it looks.
v8dave
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
