mk1 window winder chattering at top of travel
Postby ventadorn » Sun Oct 28, 2018 12:45 pm
Hi I have a 74 mk1 diesel pickup, the window winders work ok until the window gets nearly to the top, then they struggle and chatter and fail to lift the window right up. I have to help push the window up by hand but this won't of course work when I have refitted the door cards. Any cure for this?
Looking for a few bits to complete the cab, dash top, grab handle, headlining, sun visors, interior light, cancelling cam for steering column if anyone has anything. Also anyone know which window channel profile fits the side windows? Bet Woolies do something but not sure which to order
cheers
ventadorn
Re: mk1 window winder chattering at top of travel
Postby dumper » Sun Oct 28, 2018 1:23 pm
Have a look at the gear quadrant you may have stripped a tooth or two if not try slackening off everything pushing the widow up and tightening everything up
Postby ventadorn » Sun Oct 28, 2018 5:55 pm
dumper wrote:Have a look at the gear quadrant you may have stripped a tooth or two if not try slackening off everything pushing the widow up and tightening everything up
Thanks for that tip will try that when the rain eases off a bit. If the quadrant has damaged teeth maybe could rebuild with weld and file to shape.
ventadorn
Postby Neil » Sun Oct 28, 2018 6:34 pm
is the window on a lifting arm? or a cable style gear lifter
Neil v6
Neil
Postby ventadorn » Sun Oct 28, 2018 10:14 pm
Neil wrote:is the window on a lifting arm? or a cable style gear lifter
Hi it's a cable running in a sleeve
ventadorn
Postby Ralph.9 » Mon Oct 29, 2018 7:48 am
I have most of the parts on your list, new & used. I also have window winding cables if yours is worn.
Ralph.9
Postby Neil » Mon Oct 29, 2018 7:57 am
the last few inch will be worn just swap the whole part, newer the better
Neil v6
Neil
Postby ventadorn » Mon Oct 29, 2018 9:29 am
Ralph.9 wrote:I have most of the parts on your list, new & used. I also have window winding cables if yours is worn.
Ok thanks will investigate as soon as the rain stops and pm you. Thanks to everyone for their help :)
ventadorn
Return to Mk 1 & 2
