Heat Shot-windscreen washer heater.
Postby Mike » Wed Nov 14, 2018 11:43 am
Has anyone tried the Heat Shot windscreen washer heater? It heats a small amount of washer liquid in 30seconds, so helps clear ice in the winter and seems to do a better job of clearing grease and bugs in warmer weather.
It took about 40mins to fit http://www.heatshot.com/uk/
Mike
Wind up merchant!
Re: Heat Shot-windscreen washer heater.
Postby MinorMatt » Wed Nov 14, 2018 2:53 pm
Looks interesting.... but no
I would imagine a heated screen would be much better though?
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
96 P 150 TD (100PS EPIC) LWB Hi-Top
Lucas laser 2000 & IDS onwner
Gaffa tape is like the force - it has a light side, a dark side, and it holds the universe together.
Postby dumper » Wed Nov 14, 2018 4:31 pm
Years ago on one of my vans I got a long length of washer pipe and coiled it round my heater pipe to warm up the water cheep as chips not that price that’s a lot of money to spend on washers
Postby Mike » Wed Nov 14, 2018 6:13 pm
I did that on my MK6, probably the best ‘free’ mod ever.
Mike
Wind up merchant!
Postby Altransit » Wed Nov 14, 2018 6:58 pm
MinorMatt wrote:Looks interesting.... but no
Heated screens are useless when the water in the pipes is already frozen :P
Strangely, Ford fit heated washer jets to some vehicles, and then fit the water bottle in the inner wing where it goes solid. I fitted a heated transfer coil (bit of coiled copper pipe around the heater hose) on the Mk6, but the jets still used to freeze, and I never got around to fitting heated jets :P :lol:
Postby Altransit » Wed Nov 14, 2018 7:04 pm
Mike wrote:Has anyone tried the Heat Shot windscreen washer heater? It heats a small amount of washer liquid in 30seconds, so helps clear ice in the winter and seems to do a better job of clearing grease and bugs in warmer weather.
These are great, I first saw them a couple of years back, at the NEC, but I still can't get my head around the price they charge for what is, a small heat exchanger :roll:
Postby Punto443 » Wed Nov 14, 2018 7:28 pm
I fitted focus heated jets to the mk7, they made a big difference, as it’s usually the jets that freeze.
I did look at the heat shot doodah and probably would have fitted it if I’d have kept the mk7, it looked good.
From around £75 upward, and a legitimate business expense as well Al :wink:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
2019 Jeep Compass
2003 jimny
1988 xr2 (pretty beaten up the now :lol:)
Punto443
Postby Altransit » Wed Nov 14, 2018 8:44 pm
Punto443 wrote: From around £75 upward, and a legitimate business expense as well Al :wink:
Where did you find them for £75 :?:
They were around £250, and they were doing a 'show special' for £200 :shock: :mrgreen:
Postby Mike » Wed Nov 14, 2018 8:52 pm
Ebay https://www.ebay.co.uk/itm/HEATSHOT-HEA ... SwcRNZqBK5
Mike
Wind up merchant!
Postby Altransit » Wed Nov 14, 2018 9:49 pm
Cheers Mike, that's a much better price. I'll get one on order :mrgreen:
Postby Chuggy » Wed Nov 14, 2018 11:43 pm
I saw an expedition truck for Siberia that had some sort of nichrome wire coiled round the washer bottle and washer pipes up to the jets.
Chuggy
Postby ME » Thu Nov 15, 2018 12:08 am
When I started my mechanic apprenticeship in 1981 the garage I was at had a petrol fourcort as well, in the shop they sold a kit that was a small saddle like tank that was secured to the top hose then joined between the washer bottle and jets. Loads of people had them fitted, they were pretty useless, rather like this thing Mikes fitted :lol:
Look at along the lines of
A cup full of warm water hits a frozen windscreen and ........ freezes on contact. By which time you have no rubber on your wiper blades because they were stuck to the windscreen by the frost.. or you blow the fuse for the motor. If it's fitted to a mark 7 you will blow the fuse when you try to replenish the water to the unit if its cold :lol: fuse roulette :lol:
If someone could come up with a proper working solution to the frosted windscreen/ frozen jets/ frozen washer bottle etc and be able to keep a windscreen clean no matter what the weather. They would a rich person
MAN Tge Standard. 140. Fwd. Meatalic Grey.
ME
Postby bambi mk 1 » Thu Nov 15, 2018 12:18 am
ME wrote:When I started my mechanic apprenticeship in 1981 the garage I was at had a petrol fourcort as well, in the shop they sold a kit that was a small saddle like tank that was secured to the top hose then joined between the washer bottle and jets. Loads of people had them fitted, they were pretty useless, rather like this thing Mikes fitted :lol:
You could always opt for a splitte VW with an opening screen :lol:
bambi mk 1
Postby bigjohnthomas » Thu Nov 15, 2018 12:24 am
In the future transits will be autonomous and have no windows
Any view the passengers see will be augmented reality
bigjohnthomas
Postby ake » Sun Dec 02, 2018 2:15 pm
I looked at these a few times, never got round to it though!
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Return to Transit Talk
croncroncron
