The donor is a 6 stud, single wheel.Luke wrote:if its a 5 stud the mk3/4/5 is wider by a few inches
Luke wrote:unfortunatly it doesnt (at the moment) but good know as i might end up fitting 4 pots off the twin wheelerovlov wrote::roll: Dont no if this is any help Luke, But Ive had to fit another caliper to my mk4 it came off a mk3 it fitted but I had to use the mounting bracket off the mk4 but mine's a twin wheeler![]()
This pic shows how i welded up the axle to keep the alignment perfect![]()
the cling film was just to stop the threads going rusty as i kept it outside for a while
Unless I already have the tallest springs available...Luke wrote:looking good you can adjust the ride height with different spring i think ive has 2 or 3 sets on mine since ive built it
i also moved mine forward to get the wheel in the centre of the arch
Luke wrote:dont think ive stopped with thisit's just taking ages to cut out, eventually ive got it so i can offer it up to the mk1
just need time to get up there
yes i know the van needs a tidy
Luke wrote:not sure on the photos but i've still got the van
