No Pictures - available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Sun Jun 03, 2018 6:29 pm
Vision Wheel model 375 Warrior size 7,5Jx18", PCD 5x160, ET 55 mm, finishing: Phantom Chrome, Black Machined or Gloss Black Machined Face
wojciech
Postby wojciech » Sun Jun 03, 2018 7:03 pm
Ultra Wheels Co. model 450SB Toil Van , size 8,0Jx17", PCD 5x160, ET 50mm or 6,5Jx16" ET 45 mm, finishing: Satin Black Wheel or Chrome Wheel Rim
Another version: Gear Alloy model 750BM Sprinter, size 8,0Jx17", PCD 5x160, ET 50mm, finishing: Black/Milled Wheel Rim
wojciech
Postby wojciech » Wed Sep 12, 2018 3:56 pm
Mk6 alloys on Mk5
wojciech
Postby wojciech » Sat Sep 15, 2018 8:31 pm
Some new interesting pictures about Alcoa alloys - for dual wheels models. https://www.arconic.com/alcoawheels/cat ... hicles.pdf
Images that was taken by user WildThing from USA Ford Transit Forum.
He wrote:
"Finally got the Duratrac tires on the 350 HD, I used LT225/75R16. These will not fit the rears on the stock rims but with the Alcoa wheels they fit perfectly. Lock to lock, no rub in the front and the backs fit with 1/2 inch clearance on the inside to the leaf spring, and the center gap is 1/8th of a inch at low pressure. It handles amazing, I am very happy that my measurements were correct!"
wojciech
Postby wojciech » Sat Sep 15, 2018 8:43 pm
Ronals R44 on Mk8 4x4 (6,5Jx16, ET 60mm, load 1.150 kg for alloys with tapered sockets, for alloys with flat sockets was 1.300 kg)
wojciech
Postby wojciech » Thu Oct 25, 2018 4:12 pm
1AV , model Transit
size 8Jx20", PCD 5 x 160 mm, offset 50 mm, centre bore size 65.1 mm, load 1.000 kg per wheel Gloss Black, Grey and Hyper Silver.
wojciech
Postby wojciech » Thu Oct 25, 2018 5:21 pm
Previous alloys 1AV are known as AXE model TRANSIT, in one finishing Gloss Black. They are described on page 13 this thread.
New genuine 2018 Custom alloys
size 6,5J x 16", ET 60 mm, four different finishing
Image Image
wojciech
Postby wojciech » Thu Oct 25, 2018 6:03 pm
wojciech
Postby wojciech » Fri Oct 26, 2018 7:44 pm
wojciech
Postby wojciech » Sat Dec 01, 2018 3:53 pm
Riviera, model Vigor new photos on van Transit Custom
Size 7.5Jx18" ET 45mm and 8.0x20" ET 50 mm, PCD 5 x 160 mm, load 950 kg, finishing: Black, Black Polished
wojciech
Postby wojciech » Fri Jan 04, 2019 7:43 pm
Useful information on TUV and ABE Certificates
https://www.tyreleader.co.uk/tyres-advi ... rtificates
wojciech
Postby wojciech » Fri Jan 04, 2019 11:15 pm
Autec , model Type Q, size 6,5J x 16" ET 55/60 mm and 7,0J x 17" ET 54/55 mm, PCD 5 x 160 mm, CB 65,1 mm, load 1.150 kg, finishing: Brilliant silver oraz Black polished
wojciech
Postby wojciech » Mon May 06, 2019 6:02 pm
MotionR, model VS1, size 8Jx18" and 8Jx20", PCD 5 x160 mm, ET 50 mm, CB 65.1 mm, 3x colours available: Hyper Silver, Satin Gunmetal and Satin Black, load rating: 800 kg per wheel.
Their spirit of design is similar to first Transit alloys - cult Ronal RS for Mk3 (7J x 14"). Very nice, old school project...
One fault: it's really hard to keep clean.
wojciech
Postby wojciech » Mon May 06, 2019 6:25 pm
RRW/JWL, model RR6-V, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.655kg/3650 lbs (heavy duty load rating)
Compatible with TPMS Vehicle Fitment Ford Transit Manufactured...
wojciech
Postby wojciech » Mon May 06, 2019 6:32 pm
RRW/JWL, model RR6-S, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.134kg/2.500lbs
wojciech
