Parking sensors
Parking sensors
Postby Alma » Fri Nov 16, 2018 9:07 pm
Hi, my first post on here. I have just bought a 2014 transit custom limited. My only issue with it is that the parking sensors are not working. When I put it in reverse I get no sound and the symbol on the screen is the graphic of the van with an exclamation mark to the front and back. I also get that same picture on my screen when I press the parking sensor button. Any help would be appreciated. Thanks
Alma
Re: Parking sensors
Postby longhair » Sat Nov 17, 2018 2:52 pm
Hi
Mine does the same occasionally, It will work fine for a while then for some reason it doesn't. I have had a quick look at the wires going to the sensors but not found anything obvious, but as it's an intermittent fault I'm guessing its a broken connection somewhere. I have noticed though whether it a coincidence or not it works when its raining or I have just washed it.
longhair
Re: Parking sensors
Postby Alma » Sat Nov 17, 2018 3:40 pm
Yep that’s the symbol I get. I have no idea what to do next. Is there anything I can do or is it a job for the garage?
Alma
Re: Parking sensors
Postby longhair » Sat Nov 17, 2018 10:29 pm
Depends how handy you are I guess. I'm going to investigate this week and see if I can fix it myself. Like I say if it's just a bad connection somewhere it should be quite easy. I'll keep you posted how I go on.
longhair
Re: Parking sensors
Postby longhair » Mon Nov 26, 2018 8:34 am
Typical, ever since my last post they have worked every time so haven't tried to find the problem. Did you find what was causing yours not to work?
longhair
Re: Parking sensors
Postby Alma » Tue Nov 27, 2018 7:10 am
Nope, no idea. It is booked into the garage next week. Will let you know the outcome.
Alma
Re: Parking sensors
Postby Alma » Thu Dec 06, 2018 10:36 pm
Just to let you know that it was 1 sensor that had gone so apparently knocks all the others out. Changed that 1 sensor and all is good now with all of them. £40 for new sensor and £40 labour, Job done.
Alma
Re: Parking sensors
Postby Altransit » Fri Dec 07, 2018 12:19 am
Just out of interest, which sensor was it :?:
Re: Parking sensors
Postby longhair » Fri Dec 07, 2018 8:12 am
Alma wrote:Just to let you know that it was 1 sensor that had gone so apparently knocks all the others out. Changed that 1 sensor and all is good now with all of them. £40 for new sensor and £40 labour, Job done.
Cheers for letting me know. I guess I must have one on its way out then. Next time mine decides not to work I'll see if I can find it :? .
longhair
