Hi sorry for the delay been away that picture was taken half way through I will post pics of the end nowloot wrote:What is the picture when it finishes? Does it say successfully saved a cache of data etc?
Sent from my CLT-L29 using Tapatalk
I have done that and that's the pictures I'm getting i have removed a 63 reg speed limiter from a fiesta today and an 11 plate transit just having problems with the new transits and new connects it says the vin numbers don't matchloot wrote:OK so go to module programming, configuration, then configurable parameters then top option which should be download vehicle configuration. (on the page with read configuration, modify configuration, asbuilt etc about 6 options.
So first option then when that is done go to the 3rd option, modify configuration which will have all asbuilt options present) .
Then let us know what you have.
Have you done modual programming on the new transit yetBowtay wrote:I have done that and that's the pictures I'm getting i have removed a 63 reg speed limiter from a fiesta today and an 11 plate transit just having problems with the new transits and new connects it says the vin numbers don't matchloot wrote:OK so go to module programming, configuration, then configurable parameters then top option which should be download vehicle configuration. (on the page with read configuration, modify configuration, asbuilt etc about 6 options.
I have latest ids I use a good clone with 2 boards in I wonder if the vcm2 serial number is giving me the problemsloot wrote:I have it on my transit custom 65 plate (2015). But I have ids v96, v86 only works on mk7 to 2012 ish.
I had to get my vcm serial number changed also as it was old.
It only does it on the new Shape transits last time I tried on different van it said the vin was different in the abs module this time on a different van it says the vin is different in the steering angle sensorloot wrote:If you can identify the van and you can do a network test and see all the modules responded (ignore ones that aren't fitted) then I see no reason why it shouldn't work.
My pal who puts the software on was saying for late stuff it has to be on line to do module programming do you know if any one has done any late transits with the clone gear I could be trying to do something that's not possibleloot wrote:Usually it will identify the vehicle and ask you to confirm then it'll self test to check codes, you can do the network test to see which modules ids can communicate with, then you can go into module programming and read the van data which will show the page you have pictured and it'll be full of info.
So something doesn't add up.
Users browsing this forum: philpott7898
