Wanted: Di turbo 115 intercooler and injectors
Postby Liteweightldv » Wed Jan 16, 2019 1:18 am
As above looking for an intercooler for Di turbo and 115ps injectors
Liteweightldv
Re: Wanted: Di turbo 115 intercooler and injectors
Postby twin wheel camper » Fri Jan 18, 2019 2:42 am
115 hp use the same injectors as 100 hp.
twin wheel camper
Postby Liteweightldv » Fri Jan 18, 2019 10:51 am
That I was unaware of , so my smiley turbo non intercooler is same as the 115 just without intercooler
Liteweightldv
Postby twin wheel camper » Fri Jan 18, 2019 11:47 pm
Liteweightldv wrote:That I was unaware of , so my smiley turbo non intercooler is same as the 115 just without intercooler
I’m not 100% but I’ve read on here the ecu programme is also different, if you bear with this someone will confirm but the engine “map” is different to allow for the intercooler.
twin wheel camper
Postby Chug » Fri Jan 18, 2019 11:48 pm
snap:
And I'm pretty sure I heard the dcu has different settings for the injection pump for a 100 and 115 :shock:
Chug
Postby MinorMatt » Sun Jan 20, 2019 9:28 am
Injectors used by 115PS are the 33710s used by the late 100PS.
The DCU is mapped differently, 115PS has a different management system with additional parts too
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
