At this point though, I'm not sure I'm going to bother with the subwoofer. Michael Bolton and Phil Collins don't need those frequencies
Marky M wrote:Trasher83 wrote:Good luckit is enough to just remove the screen, but it is easier if you remove the facia completely, IIRC there's 4 more screws behind the screen, remove those and the facia should come off.
Here's the colorcodes for the wires:
White/White with black= left front
Gray/Gray with black stripe= right front
Green/Green with black stripe= left rear
Purple/Purple with black strips= right rear
Thanks.
Gonna post if everything is done
mic71 wrote:Marky M wrote:Trasher83 wrote:Good luckit is enough to just remove the screen, but it is easier if you remove the facia completely, IIRC there's 4 more screws behind the screen, remove those and the facia should come off.
Thanks.
Great thanks for all this info. I am going to install a new set of component speakers in the front of mine. These have a crossover in line.
What I needed to do on my 2015 custom was cut into the front speaker cables then take the output side from the stereo into the crossover unit I then took the output of the crossover to the other side of the cut cable. The run a fresh cable to the new tweeters. This all worked fine.
Are you 100% certain on these speaker cable colours?
Sorry to doubt but don't want to go cutting into the wrong cables....
mic71 wrote:Thanks for that.
Do you know if the black stripe of the pairs is + or - ?
mic71 wrote:Think you'll find it does matter.
