2007 2.4 will bump start but wont start off key
Postby MAXXED OUT » Tue Feb 12, 2019 7:54 am
Have a launch scanpad . no codes . data list showing positions of the ignition key from off thru to run and start ok .
crank data shows 45000kpa fuel pressure although no desired pressure and no injection pulse .
no issues with immobiliser data list .
Crash starts ( bump starts ) ok and runs ok . before this happened i drove the van 500km to pick up a trailer . on the way home the van would lose power so i would pull over , turn engine off for 20 seconds for the computer to shut down , restart and drive on with full power for about 15 mins ... same thing went on all the way home .. no codes when i checked it . next morning van wouldnt start.
i put new injectors and scv early last year and its been running great till now .
MAXXED OUT
Re: 2007 2.4 will bump start but wont start off key
Postby Punto443 » Tue Feb 12, 2019 8:07 am
I wouldn’t bump start it, they a very prone to jumping the timing chains if you do.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby MAXXED OUT » Tue Feb 12, 2019 9:36 am
needed to to get it out of the way and to get data while running . didnt have my scan tool when i went to pickup the trailer . would of been a big help when it was losingpower . cant replicate it now
MAXXED OUT
Postby knobby1 » Tue Feb 12, 2019 10:04 am
MAXXED OUT wrote:needed to to get it out of the way and to get data while running . didnt have my scan tool when i went to pickup the trailer . would of been a big help when it was losingpower . cant replicate it now
What Punto said.....not a good idea the bump start transits....you could end up with more trouble than just your poor starting issue.
I'm guessing your PRV has blown...common occurrence for poor starting. Pop the leakback line off it and see if there's a silly amount of fuel coming out at idle. Would pay to check the EGR function too.
Launch Scanpad may not do it for you, some readers can't see all the modules and/or functions ...you'll need IDS or Forscan.
Postby MAXXED OUT » Tue Feb 12, 2019 10:42 am
PRV is ok when testing it while running . there is no desired fuel pressure and no fuel pulse width when cranking . i have used this scantool on other transits and programmed the injectors and scv on this one , havent had too many issues with it . read on another post about ignition switch faults on these . is this just a crank issue or an issue supplying power to the ecu ? how many power outputs from the switch when cranking . starting to think it may be the switch or ecu fault ?? as cant find a reason its not commanding the injectors to pulse
MAXXED OUT
Postby knobby1 » Tue Feb 12, 2019 11:00 am
[quote="MAXXED OUT"starting to think it may be the switch or ecu fault ?? as cant find a reason its not commanding the injectors to pulse[/quote]
Could be a duff ignition switch, easy and cheap to change. The PCM won't energize the injectors if the rail pressure is low.
Postby MAXXED OUT » Tue Feb 12, 2019 11:09 am
Got 45000 kpa at crank just no desired fuel pressure . Will see if I can get a switch tomorrow
MAXXED OUT
Postby twin--turbo » Wed Feb 13, 2019 12:17 am
Does the Tranny have the Crank Sensor on the flywheel like the mondeo?
if so perhaps the dual mass FW is up the spout after pulling the trailer
twin--turbo
Postby knobby1 » Wed Feb 13, 2019 12:32 am
twin--turbo wrote:Does the Tranny have the Crank Sensor on the flywheel like the mondeo?
Yes they do....worth checking at least.
Postby MAXXED OUT » Wed Feb 27, 2019 8:18 am
Just got back onto checking the van . rechecked cranking speed on the scanpad and seemed to be fluctuating from 180rpm to 280 rpm and it was definately cranking faster than that. pulled the crank angle sensor and cleaned off the crap on its end . refitted and started first time . Thanks for the suggestions especially bringing my attention to the crank sensor . Now for a beer
MAXXED OUT
Postby MAXXED OUT » Wed Feb 27, 2019 8:54 am
I'm thinking the dual mass flywheel was slipping and putting it in limp home due to a mismatch in crank and can speeds and possibly the crank sensor got covered by the crap flung out ? Will see how long it lasts
MAXXED OUT
Postby Jim Archer » Wed Feb 27, 2019 10:36 am
The flywheel and/or reluctor can't move as it's bolted and located to the crank end - unless like mine the reluctor is a cheapo pressed steel one that comes loose.
The swarf and crap is from the bearing between flywheel and dual mass wearing, it sticking to the crank position sender messes with the Hall effect/magnetic flux field and then because the PCM sees no crank pulses, it shuts the fuel delivery off.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
